Streamlining File Saving Process in Inventor: Seeking Help with iLogic Rule Implementation
shubham.raturi2308
shubham.raturi2308
Hey Everyone,
I'm seeking assistance in writing an iLogic rule for Inventor that can help streamline our file management process. I'm looking to create a pop-up form that prompts users to fill in necessary properties before saving the file.
Any suggestions, tips, or code snippets that can help me achieve this goal would be greatly appreciated!
Thank you in advance for your support.
Best regards,
Shubham Raturi
A.Acheson
Hi @shubham.raturi2308
Create a ilogic external form video here.
Then create an external rule set an event trigger for before save and in the rule add the below code. When the document is saved the rule will start, check for an empty iproperty and start the form.
If iProperties.Value("Project", "Part Number") = "" _
OR iProperties.Value("Project", "Description") = "" Then
iLogicForm.ShowGlobal("iPropertiesForm")
End If
Regards
Alan
