edit
edit
Hi @haphanthanhtam.work . I also use the RangeBox function in my work, but I use OrientedBox. Its advantages are that it always shows the minimum size, but it only works for bodies, so it should not be used for assemblies or multibody parts. Try this code, it has a check if your component is a part and measures the OrientedBox for the first body in the part.
Public Sub Main()
' Get the active assembly.
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
Dim oUnit As UnitsOfMeasure = ThisApplication.UnitsOfMeasure
' Get the assembly component definition.
Dim oAsmDef As AssemblyComponentDefinition
oAsmDef = oAsmDoc.ComponentDefinition
' Get all of the leaf occurrences of the assembly.
Dim oLeafOccs As ComponentOccurrencesEnumerator
oLeafOccs = oAsmDef.Occurrences.AllLeafOccurrences
' Iterate through all part occurrences in assembly.
Dim oOcc As ComponentOccurrence
For Each oOcc In oLeafOccs
If TypeOf oOcc.Definition.Document Is PartDocument Then
Dim oBody As SurfaceBody = oOcc.Definition.SurfaceBodies.Item(1)
Dim oBox As OrientedBox = oBody.OrientedMinimumRangeBox
L = oUnit.ConvertUnits(oBox.DirectionOne.Length, "cm", "mm")
W = oUnit.ConvertUnits(oBox.DirectionTwo.Length, "cm", "mm")
H = oUnit.ConvertUnits(oBox.DirectionThree.Length, "cm", "mm")
Dim oList As New ArrayList
oList.Add(L)
oList.Add(W)
oList.Add(H)
Call oList.Sort()
iProperties.Value(oOcc.Name,"Custom", "Length") = Round(oList.Item(2),0)& " mm"
iProperties.Value(oOcc.Name,"Custom", "Width") = Round(oList.Item(1),0)& " mm"
iProperties.Value(oOcc.Name, "Custom", "BoxThickness") = Round(oList.Item(0),1) & " mm"
Next
End Sub
In any case, if you need the dimensions of assemblies and multibody parts, you can combine your and my version of the code.
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Thank you!!!! @Andrii_Humeniuk
It helps me get my work done quickly
