split button - separator
GeorgK
Advisor Advisor
GeorgK
Hello together,
is it possible to add a separator (line) in a split button?
Thank you very much
Georg
CCarreiras
Whaaaat!
CCarreiras
GeorgK
Thats it 🙂
Cheers Georg
Balaji_Ram
Hi Georg,
The "CommandControl.ChildControls.AddSeparator" should help with this.
Here is a sample code snippet to add to the end of the list, but you can reposition the separator by passing parameters to AddSeparator method.
Dim oSplitBtn As CommandControl
Set oSplitBtn = oPanel.CommandControls.AddSplitButton(oDef1, oDefs, True)
oSplitBtn.ChildControls.AddSeparator
Cheers,
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
GeorgK
Hello Balaji,
thanks for the sample. I could add the vertical lines but not the horizontal line in the split button.
Georg
oPanel2.CommandControls.AddSeparator()'Vert. line
' Create a split button control
Dim oDefs As ObjectCollection
oDefs = m_inventorApplication.TransientObjects.CreateObjectCollection
oDefs.Add(oButtonDefinition1)
oDefs.Add(oButtonDefinition2)
'hor. line ??
oDefs.Add(oButtonDefinition3)
Call oPanel2.CommandControls.AddSplitButton(oButtonDefinition2, oDefs, True)
Call oPanel2.CommandControls.AddSeparator() 'Vert. line
Balaji_Ram
Hi Georg,
It seems to be working ok at my end. Here is a screenshot and a slightly modified VBA code from the documentation :
Sub AddPanelToToolsTab()
    ' Get the ribbon associated with the part document
    Dim oPartRibbon As Ribbon
    Set oPartRibbon = ThisApplication.UserInterfaceManager.Ribbons.Item("Part")
    ' Get the "Tools" tab
    Dim oTab As RibbonTab
    Set oTab = oPartRibbon.RibbonTabs.Item("id_TabTools")
    ' Create a panel named "Update", positioned after the "Measure" panel in the Tools tab.
    Dim oPanel As RibbonPanel
    Set oPanel = oTab.RibbonPanels.Add("Update", "ToolsTabUpdatePanel", "SampleClientId", "id_PanelP_ToolsMeasure")
    ' Get the update commands
    Dim oDef1 As ButtonDefinition
    Set oDef1 = ThisApplication.CommandManager.ControlDefinitions.Item("AppLocalUpdateCmd")
    Dim oDef2 As ButtonDefinition
    Set oDef2 = ThisApplication.CommandManager.ControlDefinitions.Item("AppUpdateMassPropertiesCmd")
    Set oDefs = ThisApplication.TransientObjects.CreateObjectCollection
    oDefs.Add oDef1
    oDefs.Add oDef2
    Call oSplitBtn.ChildControls.AddSeparator("AppUpdateMassPropertiesCmd", True)
    ' Get the rebuild command
    Dim oDef3 As ButtonDefinition
    Set oDef3 = ThisApplication.CommandManager.ControlDefinitions.Item("AppRebuildAllWrapperCmd")
    ' Create a button control
    Call oPanel.CommandControls.AddButton(oDef3, True)
End Sub
Balaji
Balaji
GeorgK
Hello Balaji,
thank you very much. Got it running now 🙂
Georg
