Is there a iLogic rule for open a part and save in step from a assembly?
Hello
Ich want to use a rule to open a part from a assembly file, and save it as STEP
Is it posible?
When yes, please help me!
Than you!
RodrigoEiras
Sometimes it is faster if you search the forum before posting...Smiley Wink
http://forums.autodesk.com/t5/inventor-customization/macro-to-export-in-step-like-my-macro-pdf/m-p/5...
thank you but thas not that!
I want to open three files (from 10), and save it to STEP
RodrigoEiras
One suggestion:
You will get better results if instead of dropping bits of information after each post, you invest some time in explaining precisely what you want to do. That would help people to offer you a much more focused answer. And as a result you will get much better answers to your questions.
Best regards
Ok hier are a picure what i Want.
I want to make a rule, to take one part from the Browser of the assembly and save it on my local disc as a step file.
Thar rule schall every time when i save the assembly file
RodrigoEiras
I think this is basically what you need.
I hope it helps!
P.D.: To trigger it every time you save the file you should trigger it "Before Save Document"
SyntaxEditor Code Snippet
        'Get the component document
        Dim oDoc As Inventor.AssemblyDocument
           oDoc = ThisApplication.ActiveDocument 'This is the assembly
        Dim oCompDef As Inventor.ComponentDefinition
        oCompDef = oDoc.ComponentDefinition
        'Get the component file name
        Dim oDoc2 As Inventor.Document
        Dim oCompOcc As ComponentOccurrence
        For Each oCompOcc In oCompDef.Occurrences
            If oCompOcc.Name = "TestPart:1" 'here you can define which part you want to convert
                oDoc2 = oCompOcc.Definition.Document
                Trace.Writeline(oDoc2.DisplayName)
                Trace.Writeline(oDoc2.FullDocumentName)
        Next
    ' Get the STEP translator Add-In.
    Dim oSTEPTranslator As TranslatorAddIn
    oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
    If oSTEPTranslator Is Nothing Then
        MsgBox ("Could not access STEP translator.")
        Exit Sub
    Dim oContext As TranslationContext
    oContext = ThisApplication.TransientObjects.CreateTranslationContext
    Dim oOptions As NameValueMap
    oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then
        ' Set application protocol.
        ' 2 = AP 203 - Configuration Controlled Design
        ' 3 = AP 214 - Automotive Design
        oOptions.Value("ApplicationProtocolType") = 3
        ' Other options...
        'oOptions.Value("Author") = ""
        'oOptions.Value("Authorization") = ""
        'oOptions.Value("Description") = ""
        'oOptions.Value("Organization") = ""
        oContext.Type = kFileBrowseIOMechanism
        Dim oData As DataMedium
        oData = ThisApplication.TransientObjects.CreateDataMedium
        oData.FileName = "C:\Users\ERS\Desktop\temptest.stp"
        oSTEPTranslator.SaveCopyAs(oDoc2, oContext, oOptions, oData)
