sorting values
sorting values
sorting values
Is there a way to sort a certain number of values like like (-2,-1,1,2) and then take the middel 2 values and use them furter in ilogic?
i can't seem to find a command for this.
The values come from parameters. that change so they are variable.
I also posted this here https://forums.autodesk.com/t5/inventor-forum/sorting/m-p/6949688#M635484
But they recommended to poste my question here.
Thanks in advance
HermJan.Otterman
Hello Lowie,
Look at this post from yesterday,
https://forums.autodesk.com/t5/inventor-customization/determine-largest-and-second-largest-parameter...
Rhasel had a nice solution.
I Think you can use the same.
If you Always have 6 values, you need the 3e and 4e
keep in mind that it starts counting at zero so 3 = Value(2) and 4 = Value(3)
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
