So, I was using a code to automatically place part information form the IDW placed Parts List. It seems to work fin on new drawings or the first time you use it, but once that drawing is closed and you open back up, change the amount of a certain part your have in the assembly, or anything like that, it fails and gives an error. I have attached the code in a text file. Basically, all we want to do is run the rule and have it automatically place a text box under each part view with the following info, Part Number, Description, Material, & QTY. I had the rule extracting this info from the manually placed parts list in the IDW, it worked fine no matter how many times you changed something in the assembly, you could run it and everything would update, but now that the document has been closed, and re-opened, it pops an error. Any help would be greatly appreciated. We can also pull info from the BOM, that would be fine as well, just need to get the info under each part. Thanks in advance
