Solid bodies to rfa
Solid bodies to rfa
Solid bodies to rfa
I have multi-body parts with around 10 solid body each. Each solid body has to be converted to rfa. Is it possible in ilogic?
 What I did is unchecked the visibility of all solid bodies first, then turn-on the body that need to be converted. After one solid is converted, I switch it off and switch on the next one. I did it over and over until it is done.
JamieVJohnson2
So via code you can certainly automate that, but lets pause for a second with a helper idea for the user:
On the Multi-Body part file, look at the Manage ribbon tab, then \ Layout group \ Make Components command.
This will take a multi-body part and generate an assembly with individual part files all linked to this master part file.
Now you have 10 part files and don't have to turn on/off each one to export to rfa (Revit Family file).  I currently don't have the Revit add-in installed, but it too should be available for use with the api as an application addin and/or translator.
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
Im sure there is a better way to write this. But for now its all i got.
And its awfully slow, I dont know why. Please fell free to share any idea.
Sub Main()
Dim oDoc As PartDocument
oDoc = ThisDoc.Document
oCompDef = oDoc.ComponentDefinition
Dim oBodies As SurfaceBodies = oCompDef.SurfaceBodies
For Each oSolid As SurfaceBody In oBodies
	oSolid.Visible = False
Next
	oSolid.Visible = True
	Dim oSolidName As String = oSolid.Name
'	Dim oBIMOrientType As BIMComponentOrientationTypeEnum
'	oBIMOrientType = kUserCoordinateSystemOrientationType
	Dim FullFileName As String = "C:\Users\Joseph\Desktop\Inventor Study\ToRFA\" & oSolidName & ".rfa"
	oCompDef.BIMComponent.ExportBuildingComponent(FullFileName)
Next
For Each oSolid As SurfaceBody In oBodies oSolid.Visible = True Next End Sub
