Skipping question ' save changes to ... and its dependents? '
I have a little problem:
When I save my assembly (Assemblydoc.save) my VB-routine stops and I get the question: "Do you want to save changes to ... and its dependents?"
Is it possible to skip this question and automatically save the assembly and his dependents?
Greets,
Peter
Try this:
oApp.SilentOperation = True
Assemblydoc.Save
oApp.SilentOperation = False
When SilentOperation is True, Inventor doesn't
display any dialogs but proceeds using what the default of the dialog would have
been.
-Brian
and his dependents?
Greets,
Peter
Try this:
      Dim oFileSaveAs As
FileSaveAs
        Set
oFileSaveAs = oApprentice.FileSaveAs
        Call
oFileSaveAs.AddFileToSave(oDoc,
SvAs)
        Call
oFileSaveAs.ExecuteSave
Mike Martin
Try this:
Assemblydoc.Save
have been.
-Brian
and his dependents?
Greets,
Peter
Thank you Brain,
It works!
Greets
Peter
Where do you put that code?
MechMachineMan
After you assign the application object variable and before you start doing anything with it, then also add the inverse before your code exits.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
The API includes a Document.Save2 Method (PartDocument, AssemblyDocument, DrawingDocument, PresentationDocument as well) that saves the document and dependent documents. This would prevent the need to mess around with the Application object. This is directly from the API docs. NOTE the RED text in the Remarks section.
Parent Object: Document
Description
Method that saves the document and the specified dependent documents.
Syntax
Document.Save2( [SaveDependents] As Boolean, [DocumentsToSave] As Variant )
Parameters
NameDescription
SaveDependentsOptional input Boolean that specifies whether or not to save dependent documents that have been dirtied. Defaults to True indicating that the dependents will be saved. If the DependentsToSave argument is not specified, all dirty dependents are saved. If the argument is specified as False, only this document will be saved. The argument is ignored if the document doesn't have any dependents needing save.
DocumentsToSaveOptional input ObjectCollection that contains the Document objects to save. Use the Document.AllReferencedDocuments property to iterate over all dependent documents and find the ones that need to be saved (i.e. Dirty property returns True). If the SaveDependents argument is True and this argument is not specified, all dirty documents are saved. The argument is ignored if the document doesn't have any dependents needing save.
Remarks
If the document has never been saved, calling this method prompts the user for a file name just like the Save method. Calling Document.Save2 without specifying any arguments results in the dirty dependents getting saved. The "Save Dependents" dialog is not displayed (the Save method does display the dialog).
Version
Introduced in Inventor version 2010
