- Mute
- Permalink
- Report
Sub Main() AddOrInsertPromptedSymbol() InsertSymbolsNextToDimensions() End Sub Sub AddOrInsertPromptedSymbol() Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument Dim symbolName As String = "My Symbol" Dim found As Boolean = False ' Check if symbol definition already exists For Each oSymbolDef As SketchedSymbolDefinition In oDoc.SketchedSymbolDefinitions If oSymbolDef.Name = symbolName Then found = True Exit For End If Next If found Then Return ' Create the sketched symbol definition Dim oSymbolDefNew As SketchedSymbolDefinition = oDoc.SketchedSymbolDefinitions.Add(symbolName) Dim oSketch As DrawingSketch = Nothing oSymbolDefNew.Edit(oSketch) ' Draw a circle and add prompted text box in the symbol sketch Dim oCenter As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(12, 12) oSketch.SketchCircles.AddByCenterRadius(oCenter, 0.25) Dim promptPlaceholder As String = "<Prompt>Enter Text</Prompt>" Dim oTextBox As TextBox = oSketch.TextBoxes.AddFitted(oCenter, promptPlaceholder) oSymbolDefNew.ExitEdit(True) ' Do NOT insert the symbol instance here to avoid error on first run End Sub Sub InsertSymbolsNextToDimensions() Dim oDoc As DrawingDocument = ThisDoc.Document Dim oSymDef As SketchedSymbolDefinition ' Get the "BA" sketched symbol definition Try oSymDef = oDoc.SketchedSymbolDefinitions.Item("My Symbol") Catch ex As Exception MsgBox("Sketch Symbol 'BA' not found: " & ex.Message) Exit Sub End Try Dim counter As Integer = 1 Dim offsetX As Double = 0.5 Dim offsetY As Double = 0.2 Dim oTG As TransientGeometry = ThisApplication.TransientGeometry For Each oSheet As Sheet In oDoc.Sheets Dim oDims As GeneralDimensions = oSheet.DrawingDimensions.GeneralDimensions For Each oDim As GeneralDimension In oDims Dim dimPt As Point2d = oDim.Text.Origin Dim symPt As Point2d = oTG.CreatePoint2d(dimPt.X + offsetX, dimPt.Y + offsetY) Dim oLeaderPoints As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection() ' Create geometry intent at the dimension location Dim oIntent As GeometryIntent = oSheet.CreateGeometryIntent(oDim, dimPt) oLeaderPoints.Add(symPt) oLeaderPoints.Add(oIntent) Dim promptValues(0) As String promptValues(0) = counter.ToString() Try Dim oSketchedSymbol As SketchedSymbol = oSheet.SketchedSymbols.AddWithLeader(oSymDef, oLeaderPoints, 0, 1, promptValues) oSketchedSymbol.Static = True oSketchedSymbol.LeaderVisible = False Catch ex As Exception MsgBox("Error placing symbol " & counter & ": " & ex.Message) End Try counter += 1 Next Next End Sub
This rule -lace the sketched symbols with counter to the all dimensions. the symbol is associate to the dimension text. i use geometry intent for that. for angles it didn't place the symbol and get error, please anyone help to solve this issue.
