SKETCH SYMBOL WITH DATA FROM EXCEL TABLE
Victor.Tuguinay
Victor.Tuguinay
I am wondering if it would be possible to create a sketch symbol using data from an excel file using ilogic.
My table looks like this.
The sketch symbol that I would like to create will be in this format.
Example output will look like this. The sketch symbol will be rotated by orientation (α). I am looking for something where I can specify the orientation like 10 deg and it will create the sketch symbol as shown below.
I am thinking user will be prompted to enter the angle (orientation). Then the program will retrieve the values for METRIC and IMPERIAL from the excel table. After that, it will insert the sketch symbol into the drawing showing the retrieved and prompted (α) values. The sketch symbol will also be rotated by the prompted angle (α).
Curtis_Waguespack
Hi @Victor.Tuguinay,
Here is a quick version of this, you might need to adjust it a bit.
Currently, it expects:
  • a sketched symbol with 3 prompted entry fields
  • a spread sheet such as this:
And as written it places a symbol at a static point (10,15) .
I'm sure it's not exactly what you are after, but it should get you close.
I hope this helps.
Curtis
oPath = "C:\Temp\Server\"
oFile = oPath & "SketchSymbol_Info.xlsx" 'uses the above path to find the excel file
oSymbolName = "SymbolA"
Dim oList = New Double() {10, 20, 30 }
oInput = InputListBox("Prompt", oList, oList(0), "iLogic", "List")
GoExcel.FindRowStart = 2
iRow = GoExcel.FindRow(oFile, "Sheet1", "Orientation", "=", oInput)
oOrientation = GoExcel.CellValue(oFile, "Sheet1", "A" & iRow)
oMetric = GoExcel.CellValue(oFile, "Sheet1", "B" & iRow)
oImperial = GoExcel.CellValue(oFile, "Sheet1", "C" & iRow)
Dim oDoc As DrawingDocument = ThisDrawing.Document
Dim oSheet As Sheet = oDoc.ActiveSheet
Dim oSymDef As SketchedSymbolDefinition = oDoc.SketchedSymbolDefinitions.Item(oSymbolName)
Dim sPromptStrings(2) As String
sPromptStrings(0) = oOrientation &  Chr(176)
sPromptStrings(1) = oMetric
sPromptStrings(2) = "[" & oImperial & "]"
Dim oPosition As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(10, 15)
oRotation = oOrientation * PI / 180
Dim oSymbol As SketchedSymbol
oSymbol = oSheet.SketchedSymbols.Add(oSymDef, oPosition, oRotation, 1, sPromptStrings)
