Solid Convert to Sheet VB.NET API
florian_wenzel
Message 1 of 17
florian_wenzel
Hi
Inventor 2022
VB.NET API  with Visual Studio
I try to Convert Solid Modell to Sheet Metall
The Goal is, we are in Part Document and we make a Autmation to Convert Solid do Sheet Metall, with declaration of Thickness of material.
I have a half of this.
I need manually:
  • click Convert to SheetMetall
  • Set the Material Thickess
then i use the CODE:
Imports System.Runtime.InteropServices
Imports Inventor
Imports Microsoft.Win32
Module CommandFunctionButton_07
Public Sub CommandFunctionfweButton_07()
Dim oPartDoc As PartDocument = g_inventorApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition
Dim oTO As TransientObjects = g_inventorApplication.TransientObjects
Dim oTG As TransientGeometry = g_inventorApplication.TransientGeometry
Dim oFaceCurved As Face = CType(g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Pick a Face"), Face)
Dim oSheetCompDef As SheetMetalComponentDefinition
oSheetCompDef = oPartDoc.ComponentDefinition
Dim oSheetMetallFeatures As SheetMetalFeatures
oSheetMetallFeatures = oSheetCompDef.Features
Call oSheetMetallFeatures.UnfoldFeatures.Add(oFaceCurved, , )
End Sub
End Module
How to make the Convert to SheetMetal?
I was looking in help.Autodesk.Inventor
in:
SheetFeatures
PartFeatures
PartDocument.SubType Property
SheetMetalCheckGUID = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"
DocumentTypeEnum Enumerator
etc...
but i was Find Nothing.
Thanks for any Sugestion.
Accepted solutions (4)
Replies (16)
Message 2 of 17
Michael.Navara
Conversion is made this way:
'To standard part
ThisApplication.ActiveDocument.SubType  = "{4D29B490-49B2-11D0-93C3-7E0706000000}"
'To sheetmeatl part
ThisApplication.ActiveDocument.SubType  = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"
Message 3 of 17
florian_wenzel
thanks very much.
hmm, that's not all.
I need figure out, how to define the Material Thickness and all necessary info, to make the Unfold.
Because without this data, it crash.
Message 4 of 17
florian_wenzel
My CODE:
Imports Inventor
'To sheetmeatl part
g_inventorApplication.ActiveDocument.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"
Dim oSheetCompDef As SheetMetalComponentDefinition = oPartDoc.ComponentDefinition
Dim oSheetMetallFeatures As SheetMetalFeatures = oSheetCompDef.Features
Dim oStyle As SheetMetalStyle
oStyle = oSheetCompDef.SheetMetalStyles.Item(1)
oStyle.Material = oPartDoc.Materials.Item(1)
End Sub
End Module
Is possible to use default settings, or that will automaticly recognize the Thickenss of the Material?
Thanks for any sugestion
Message 5 of 17
Michael.Navara
This is sample iLogic code, how to convert standard part to sheetmetal and setup basic properties and unfold.
'get target document
Dim part As PartDocument = ThisDoc.Document
'Convert to Sheetmatel part
part.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"
'Select top and bottom face
Dim topFace As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFacePlanarFilter, "Select top face")
Dim bottomFace As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFacePlanarFilter, "Select bottom face")
'Calculate thickness
Dim thickness As Double = ThisApplication.MeasureTools.GetMinimumDistance(topFace, bottomFace)
'Get sheetmetal component definition
Dim smCompDef As SheetMetalComponentDefinition = part.ComponentDefinition
'Setup thickness
smCompDef.UseSheetMetalStyleThickness = False
smCompDef.Thickness.Value = thickness
'Setup ASide (top face for unfolding)
smCompDef.ASideFace = topFace
'Create flat pattern
smCompDef.Unfold()
Message 6 of 17
florian_wenzel
thanks very much.
I need to do this in VB.NET with Visual Studio.
i dont want to jump between Autmatization in VS and ilogic.
im not a fun of ilogic 🙂
This my CODE, but still error:
Imports Inventor
oStyle.Thickness = "5"
oStyle.BendRadius = "Thickness * 1.5"
oStyle.BendReliefDepth = "Thickness * 1.5"
oStyle.BendReliefShape = BendReliefShapeEnum.kRoundBendReliefShape
oStyle.BendReliefWidth = "Thickness / 2"
oStyle.BendTransition = BendTransitionEnum.kArcBendTransition
oStyle.BendTransitionArcRadius = "Thickness * 2.0"
oStyle.CornerReliefShape = CornerReliefShapeEnum.kRoundCornerReliefShape
oStyle.CornerReliefSize = "Thickness * 2.0"
oStyle.MinimumRemnant = "Thickness * 2.0"
End Sub
End Module
Message 7 of 17
WCrihfield
Hi @florian_wenzel.  I can not read what the error message says, because it is in a language that I'm not fluent in, but it seems to be acting like it doesn't recognize the "Thickness" parameter name.  That is a standard Parameter that is created within all sheet metal parts, and I don't think it changes in other languages, for stability.  So, maybe try including a line of code to update the document after the SubType conversion (oPartDoc.Update).  It may just need a moment to process all the changes, before accessing sheet metal specific parameters.
Wesley Crihfield
(Not an Autodesk Employee)
Message 8 of 17
florian_wenzel
no, still error
Wrong Parameter
Maybe, i dont understand this well, and i put this wrong
Imports Inventor
        oPartDoc.Update()
        oStyle.BendRadius = "Thickness * 1"
        oStyle.BendReliefDepth = "Thickness * 1"
        oPartDoc.Update()
    End Sub
End Module
i need to make Automatization of this Button or Method
"Sheet Metal Defaults" - In Englisch
Message 9 of 17
WCrihfield
When you look in your Parameters dialog box on a 'new' sheet metal part, do you see a Parameter named "Thickness", or is your named "Starke"?  In my English version of Inventor, when I open a new sheet metal part, there are 9 default 'sheet metal parameters' in their own parameter group above the 'model parameters'.  If your parameter is named "Starke" instead of "Thickness", then you will have to use "Starke" within your quoted values, for them to reference the correct parameter name.
Wesley Crihfield
Message 10 of 17
florian_wenzel
yes, you right :), thanks
but still not working
It is strange, because now i get Error by UnfolfFeature.
This Line should working Fine.
Because the Code below is working, when i manually convert Part to SheetMetall and manually Set the Thickness.
Then the UnfoldFeature work fine.
As you mentioned before, the Paramter dialogBox.
Maybe this Error is because the Parameter Value is wrong etc..
Message 11 of 17
florian_wenzel
ok is Working !
Thanks 🙂
Imports Inventor
        oPartDoc.Update()
        oStyle.Thickness = "50"
        oStyle.BendRadius = "Stärke"
        oStyle.BendReliefDepth = "Stärke * 0,5"
        oStyle.BendReliefWidth = "Stärke"
        oStyle.BendTransitionArcRadius = "Stärke * 2.0"
        oStyle.CornerReliefSize = "Stärke * 4.0"
        oStyle.MinimumRemnant = "Stärke * 2.0"
        oPartDoc.Update()
    End Sub
End Module
it is Strange, because i was Thinking, that the units is "cm" and not "mm"
in foto from Viusal Studio Line 24
the Value is 50
before was 5, because i was thinking, that should be "cm"
And in other Script, i was using cm.
But the Function Works.
Message 12 of 17
WCrihfield
Glad to hear you finally got everything working.  When using quoted input for parameter values, like when setting the Expression of a Parameter, the units will Not be automatically converted.  They will be understood the same as if you typed it into the expression box within the parameters dialog box.  That is often the best way to deal with parameters.
Wesley Crihfield
Message 13 of 17
florian_wenzel
still a question to this Topic:
how to set/change the "kFactor"
for exampe on value 0.5
I got a Errror, this is my Code:
Imports Inventor
        oPartDoc.Update()
        oStyle.Thickness = dist * 10
        oPartDoc.Update()
        Dim okFactor As String
        okFactor = "0.5"
        Dim okFactorUnfoldMethod As UnfoldMethod
        okFactorUnfoldMethod = oSheetCompDef.UnfoldMethods.kFactor(okFactor)
        oPartDoc.Update()
    End Sub
End Module
The Error:
The Public Member kFactor for UnfoldMethods, not found
When i change the UnfoldMethods on UnfoldMethod,
the i got Error:
The Value of type Char, can not be Convert to UnfoldMethod
Message 14 of 17
WCrihfield
Hi @florian_wenzel.  It looks to me like you are going a step too far with that one line of code (line 38).  The code on line 37 just created a variable of Type UnfoldMethod, without setting its value, then line 38 should only be setting the value of that UnfoldMethod type variable, not also attempting to set a property value within the UnfoldMethod too.  You can attempt to set the value of the UnfoldMethod's kFactor on the next line after that, just before the update code.
Also, up on line 45, I noticed that you used a comma within your specified numerical value "Starke * 0,5", instead of a dot (.), but then you are using a dot in all your other numerical values.  Is that a mistake, or intentional.
Wesley Crihfield
Message 15 of 17
florian_wenzel
hi,
not exactly undertood this
My Code:
Imports Inventor
        oPartDoc.Update()
        oStyle.BendReliefDepth = "Stärke * 0.5"
        oPartDoc.Update()
        okFactor = "0.5"
        Dim okFactorUnfoldMethod As UnfoldMethod.kFactor(okFactor)
        oPartDoc.Update()
    End Sub
End Module
Still Error
or like this?
Imports Inventor
        oPartDoc.Update()
        oPartDoc.Update()
        okFactor = "0.5"
        kFactor(okFactor)
        oPartDoc.Update()
    End Sub
End Module
Now the kFactor is without declaration.
Message 16 of 17
WCrihfield
Are you just trying to change the kFactor of the currently 'active' UnfoldMethod, or are you trying to create a new UnfoldMethod, then set that as the 'active' UnfoldMethod?
If you are just trying to change the kFactor of the currently 'active' UnfoldMethod, then you should be able to use something like the following:
oSheetCompDef.UnfoldMethod.kFactor = "0.5" 'or = okFactor
But if you are trying to create a New UnfoldMethod, then set that as the 'active' one, then you should be able to use something like the following:
okFactorUnfoldMethod = oSheetCompDef.UnfoldMethods.AddLinearUnfoldMethod("MyUnfoldMethod", "0.5")
oSheetCompDef.UnfoldMethod = okFactorUnfoldMethod
Wesley Crihfield
Message 17 of 17
florian_wenzel
Yes, now i get it.
Thanks.
