Sketch - Rectangular & Circular Arrays
isocam
Message 1 of 12
isocam
Can anybody help!
I am extracting all coordinates of sketch entities (eg  Line start & end points, arc centre radius start and end angle etc)
Everything is OK except that I have come across a ipt file containing a sketch that is copied in a "Rectangular Array".
Is there any way I can get the Rectangular & Circular Arrays dimensional date (eg Number of rows, number of columns, pitch etc)?
Many thanks in advance!!!
IsoCAM
Replies (11)
Message 2 of 12
Vladimir.Ananyev
Will you please upload a sample model to simplify test.
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Message 3 of 12
isocam
Please find,attached, a sample file.
Message 4 of 12
Vladimir.Ananyev
Rectangular pattern is controlled by RectangularPatternFeature object.
The following VBA sample illustrates several properties of this object.
The complete description you may find in the Inventor API Help.
Private Sub Test_RectPattern()
  Dim oDoc As PartDocument
  Set oDoc = ThisApplication.ActiveDocument
  Dim oDef As PartComponentDefinition
  Set oDef = oDoc.ComponentDefinition
  'reference to rect. pattern
  Dim oRP As RectangularPatternFeature
  Set oRP = oDef.Features.RectangularPatternFeatures _
              .Item("Rectangular Pattern1")
  Dim oPar As Inventor.Parameter
  'number of elements along X and Y
  Set oPar = oRP.XCount
  Debug.Print "XCount = " & oPar.Value & "  Par: " & oPar.Name
  Set oPar = oRP.YCount
  Debug.Print "YCount = " & oPar.Value & "  Par: " & oPar.Name
  'Spacing (cm) along X and Y
  Set oPar = oRP.XSpacing
  Debug.Print "XSpacing(cm) = " & oPar.Value & "  Par: " & oPar.Name
  Set oPar = oRP.YSpacing
  Debug.Print "YSpacing(cm) = " & oPar.Value & "  Par: " & oPar.Name
  'reference to feature
  Dim oObjColl As ObjectCollection
  Set oObjColl = oRP.ParentFeatures
  Dim oExtr As ExtrudeFeature
  Set oExtr = oObjColl.Item(1)
  Debug.Print "Feature = " & oExtr.Name
  'references to all pattern elements
  Dim i As Integer
  Dim oFPE As FeaturePatternElement
  For i = 1 To oRP.PatternElements.Count
    Set oFPE = oRP.PatternElements.Item(i)
    Debug.Print i & "  Suppressed: " & oFPE.Suppressed
  Next i
End Sub
 Result with your model:
XCount =        2  Par: d12
YCount =        2  Par: d15
XSpacing(cm) = 25  Par: d14
YSpacing(cm) = 31  Par: d17
Feature = Extrusion2
1  Suppressed: False
2  Suppressed: False
3  Suppressed: False
4  Suppressed: False
Cheers,
Vladimir Ananyev
Message 5 of 12
isocam
Here is my "Function", so far...
Public Function ArrayGeometry(Doc As PartDocument)
  Set oDef = Doc.ComponentDefinition
  Set oRP = oDef.Features.RectangularPatternFeatures.Item("Rectangular Pattern1")
  Select Case FeatureType
    Case "Rectangular"
         Set oPar = oRP.Xcount
         Xcount = oPar.Value
         Set oPar = oRP.Ycount
         Ycount = oPar.Value
         Set oPar = oRP.Xspacing
         Xspacing = oPar.Value * 10
         YSpacing = oPar.Value * 10
         Dim i As Integer
             If oFPE.Suppressed = False Then Call RectangularArray
         Next i
    Case "Circular"
  End Sub
End Function
If I have more than one "Rectangular Array", how do I implement that and also What if the array is "Circular"
Can you help?
Kindest Regards
IsoCAM
Message 6 of 12
Vladimir.Ananyev
Features object has property for every kind of features.
You can find references to all cirlular patterns via the following  property:
Features.CircularPatternFeatures() As CircularPatternFeatures.
See Inventor API Help article on CircularPatternFeature object.
Cheers,
Vladimir Ananyev
Message 7 of 12
isocam
Can you give me an example vba macro that can do both "Rectangular" and "Circular" arrays?
Say my inventor part (ipt) has multiple "Rectangular" and "Circular" arrays. How can I get the array info (Number of repeats etc)
Many thanks!!
IsoCAM
Message 8 of 12
Vladimir.Ananyev
You should process RectangularPatternFeatures and CircularPatternFeatures collections separately.
Each collection has Item and Count properties.
Here is the sample for circular pattern:
Private Sub Test_CircPattern()
  'reference to circular pattern directly by name
  Dim oCP As CircularPatternFeature
  Set oCP = oDef.Features.CircularPatternFeatures _
              .Item("Circular Pattern AAA")
  Dim oPar As Inventor.ModelParameter
  'extended name
  Debug.Print "Extended name:   " & oCP.ExtendedName
  'number of elements
  Set oPar = oCP.Count
  Debug.Print "Count = " & oPar.Value & "  Par: " & oPar.Name
  'angle
  Set oPar = oCP.Angle
  Debug.Print "Angle (rad) = " & oPar.Value & "  Par: " & oPar.Name
End Sub
Result:
Extended name:   (x 7 ul x 180 deg)
Count = 7  Par: d9
Angle = 3.14159265358979  Par: d10
 Cheers,
Vladimir Ananyev
Message 9 of 12
isocam
Please refer to the attached Module. (Extension changed to txt)
My Inventor part (ipt) can have either a single "Rectangular" array, or a single "Circular" array or multiple "Rectangular" or "Circular" arrays.
At the moment it can only handle "Rectangular Pattern1" or". "Circular Pattern1"
How can the, attached, macro be changed so that it goes through each "Rectangular" or "Circular" array in turn.
Many thanks in advance!!!!
IsoCAM
Message 10 of 12
Vladimir.Ananyev
I think the framework of your procedure should be similar to the followng sample:
Public Sub PartPatterns()
  'number of rect. patterns
  Dim N1 As Integer
  N1 = oDef.Features.RectangularPatternFeatures.Count
  'number of circ. patterns
  Dim N2 As Integer
  N2 = oDef.Features.CircularPatternFeatures.Count
  'process all rect. patterns
  Debug.Print "   We have " & N1 & " rect. patterns:"
  For Each oRP In oDef.Features.RectangularPatternFeatures
    'do everything you want with this oRP
    Debug.Print oRP.Name
  Next
  Debug.Print
  'process all circ. patterns
  Debug.Print "   We have " & N2 & " circ. patterns:"
  For Each oCP In oDef.Features.CircularPatternFeatures
    'do everything you want with this oCP
    Debug.Print oCP.Name
  Next
  Debug.Print
End Sub
 Cheers,
Vladimir Ananyev
Message 11 of 12
isocam
I have only one real issue with the macro. It arrays every sketch in my part
Is there a way of only allowing sketch entities to be "arrayed" if that sketch entity has an associated array attached to it?
I the sample there are holes spaced equally on a "pitch circle diameter" the holes are arrayed.
The output I am getting also arrays the first sketch, that is the circle that makes up the outer plate.
This sketch (sketch1) is also arrayed, even though the sketch does not have an associated array.
Is there a way to filter out sketches that do not have an associated array?
IsoCAM
Message 12 of 12
Vladimir.Ananyev
If you need information on specific feature pattern you should use its name or pick it via UI (you do not need to use any sketches at all).
For example your part TestPlate.ipt includes the hole feature circular pattern.  This pattern is accessible by its name as it was shown in Sub Test_CircPattern()  posted on Nov-08-2012.
Name = “Circular Pattern1”
Your function Function ArrayGeometry(Doc As PartDocument, sketch As PlanarSketch) should have the feature pattern name in the second argument instead of the reference to the planar sketch.
Vladimir Ananyev
