Disable Screen Updating via iLogic
Message 1 of 8
I am using iLogic to change assembly dimensions, suppress components and constrains. Is there any way to turn off screen updating while iLogic rules are running?
Replies (7)
Message 2 of 8
Vladimir.Ananyev
Please try this method:
  ThisApplication.ScreenUpdating = False
            ... some iLogic commands ...
  ThisApplication.ScreenUpdating = True
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Message 3 of 8
Спасибо, работает Smiley Happy
Message 4 of 8
Well it works Smiley Sad but not quite as I would expect. In my case Inventor gets frozen. Then only way to restart Inventor is to use Windows Application Manager shot down process and restart.
Message 5 of 8
Vladimir.Ananyev
Try this format:
    Try
      ' ... rule code ...
    Catch ex As Exception
      'if some error occurs then this code will be executed
      ThisApplication.UserInterfaceManager.UserInteractionDisabled = False
      Beep()
      MsgBox("Error info: " & vbNewLine & ex.ToString)
    End Try
  Cheers,
Vladimir Ananyev
Message 6 of 8
"Try" code piece runs without any errors.
Soon I set   string  ThisApplication.ScreenUpdating = False
in front of my iLogic code Inventor freezes in quite funny way
Smiley Sad
Message 7 of 8
Vladimir.Ananyev
Will you please post your  rule / model / some description.
Vladimir Ananyev
Message 8 of 8
We recently moved on Inventor 2013 and strugling to get our models and drawing to work. It is quite a mess here. I would like to postpone this subject for a while as I simply have no time for more testing.
Thank you for your kind attention in this matter.
