Simulate Pressing the "Start 2D Sketch" button.
chaines59GWR
chaines59GWR
Hello all!
Does anyone know how to "Simulate" having pressed the "Start 2D Sketch" button in the toolbar? I am creating a program that will create new parts and then I want the user to be able to choose what axis they start their sketch on.
I could program that myself, but I figure using Inventors built in methods may be nicer. Below is what I have so far, I can get into the part to edit it but I'm not sure how to trigger the sketch creator.
Function CreateFiles(ProjectFolder As String, ProjectName As String)
	Dim Origin As Matrix = ThisApplication.TransientGeometry.CreateMatrix()
	Dim oPart As PartDocument = ThisApplication.Documents.Add(kPartDocumentObject,,False)
	oPart.SaveAs(ProjectFolder & "\" & ProjectName & ".ipt", False)
	oPart.Close
	Dim oAsm As AssemblyDocument = ThisApplication.Documents.Add(kAssemblyDocumentObject)
	oAsm.SaveAs(ProjectFolder & "\" & ProjectName & ".iam", False)
	Dim oOcc As ComponentOccurrence = oAsm.ComponentDefinition.Occurrences.Add(ProjectFolder & "\" & ProjectName & ".ipt", Origin) : oOcc.Grounded = True
	With ThisApplication.ActiveView.Camera
		.ViewOrientationType = ViewOrientationTypeEnum.kIsoTopRightViewOrientation
		.Fit
		.ApplyWithoutTransition
	End With
	Dim oOccDef As PartComponentDefinition = oOcc.Definition
	oOcc.Edit
End Function
Thanks!
hollypapp65
It is a internal command: PartNewSketchCmd
You can run it:
	Dim oControlDef As Inventor.ControlDefinition
	oControlDef = ThisApplication.CommandManager.ControlDefinitions.Item("PartNewSketchCmd")
	oControlDef.Execute2(True)
You can use "EventWatcher" from SDK to get the command name.
chaines59GWR
Beauty! Thanks!
