Rename all files and subfiles names in with API VB.NET?
mucip
mucip
I can change all files and subfiles names (Not occurence. Real file names) in SolidWorks in Model Tree. But I can not do the samething in Inventor. When I rename the part/assembly then I can change only occurence name. By the way I wrote code in SW to change tons of Parts/Assemblies files names with one button. I use ordinary file names for all files like
ModelA-00001
ModelA-00002
ModelA-00003
etc...
I use this when I want to create new version of the all assembly model with the new numbers like below:
ModelB-00001
ModelB-00002
ModelB-00003
etc...
I can update all source of drawing files with the new file names. This is also very important.
In SW this is not so difficult with API. I want to do same thing in Inventor API.
Could you please guide me?
Mucip:)
JelteDeJong
Renaming files can be done using the API but Inventor and vault have both tools to create design copies. Did you have a look at these options:
Copying an Inventor assembly using iLogic Design Copy
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Copying-an-Invento...
Have You Tried: Copy Design
https://help.autodesk.com/view/VAULT/2024/ENU/?guid=GUID-CA59F765-6BE5-47C6-8EF5-B9D427854D97
These options are way easier than creating your own rule.
Jelte de Jong
Blog: hjalte.nl - github.com
mucip
First time I saw.
OK. I will check it. But we don't use VAULT.
Anyway. I check. Thanks.
Mucip:)
