Show sketch of body by picking
tim11_manhhieu
tim11_manhhieu
Hi all,
I'm trying to write a macro to show sketch of a body using picking, but I'm stucking at getting sketch of oFeature.
I want to show Sketch 2 of Extrusion2 of body P37.
My code will probably be long, if you have shorter code please share.
Thanks in advance.
Option Explicit
Sub ShowSketchBody()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oObj As Object
Set oObj = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter, "Pick a body:")
Dim oBody1 As SurfaceBody
Set oBody1 = oObj
Dim oBodies As SurfaceBodies
Set oBodies = oDoc.ComponentDefinition.SurfaceBodies
Dim oBody2 As SurfaceBody
Dim oFeature As PartFeature
For Each oBody2 In oBodies
    If oBody2.name = oBody1.name Then
        For Each oFeature In oBody1.AffectedByFeatures
            If oFeature.HealthStatus = kUpToDateHealth Then
'                //I'm stucking here, dont know how to get sketch of oFeature//
        Next
Next
End Sub
Michael.Navara
Hi @tim11_manhhieu
This is iLogic code instead of VBA, because it can be shorter, but if you need VBA, it can be reworked.
This code make visible all extrude sketches. If you want, you can break the For-Each loop after first iteration.
Dim pick = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter, "Pick body")
Dim body1 As SurfaceBody = pick
For Each extrudeFea As ExtrudeFeature In body1.AffectedByFeatures.OfType(Of ExtrudeFeature)
	Dim sk As PlanarSketch = extrudeFea.Profile.Parent
	sk.Visible = True
	'Exit For 'For the first sketch only
Next
tim11_manhhieu
thanks for your respond, it is amazing. VBA code for Extrude Feature and Hole Feature below.
Option Explicit
    Dim oObj As Object
    Dim body As SurfaceBody
    Dim partFea As PartFeature
    Set oObj = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter, "Pick body: ")
    If TypeOf oObj Is SurfaceBody Then
        Set body = oObj
        For Each partFea In body.AffectedByFeatures
            If TypeOf partFea Is ExtrudeFeature Then
                Set sk = partFea.Profile.Parent
                sk.Visible = True
            If TypeOf partFea Is HoleFeature Then
                Set sk = partFea.sketch
                sk.Visible = True
        Next partFea
End Sub
