Simple UNDO rule
Simple UNDO rule
Simple UNDO rule
Can anyone show me a code that does an UNDO in a document. Thank you guys for the replies.
bradeneuropeArthur
Is Possible:
Check this:
Dim oTransMgr As TransactionManager
Dim m_inventorApplication as inventor.application
m_inventorApplication = thisapplication
oTransMgr = m_inventorApplication.TransactionManager Dim oTrans As Transaction oTrans = oTransMgr.StartTransactionForDocumentOpen("DEscription Of the Command") 'YOUR CODE HERE 'YOUR CODE HERE oTrans.End()
 The rule or command can now simply being undo with the undo button in Inventor or Ctrl+Z
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @Anonymous,
Hoping that following iLogic code would help.
Dim oCommandMgr As CommandManager
oCommandMgr = ThisApplication.CommandManager
' Get control definition for the line command.
Dim oControlDef As ControlDefinition
 oControlDef = oCommandMgr.ControlDefinitions.Item( _
                                             "AppUndoCmd")
' Execute the command.
Call oControlDef.Execute
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
bradeneuropeArthur
This is only the undo command from the commandmanager. But with the transactionmanager you are able to undo a specific command.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Thanks, both of you. I got what I needed.
engilic
just use:
ThisApplication.CommandManager.ControlDefinitions.Item("CommandName").Execute
CommandName you can find here:
https://github.com/AlexFielder/iLogic/blob/master/CommandNames.txt
ktelangCGFU6
Thanks this transaction handling helped me
