Simple Material Question
matt_jlt
matt_jlt
I have another question, I have a macro that i want to change my part's active render style to as material, the only problem is that i have a combo box with all of the render styles and the macro takes the selected value as the style to use. I know you can do this with:
oPartDoc.ActiveRenderStyle = _
oPartDoc.ComponentDefinition.Material.RenderStyle
but it doesn't exactly fit into the combo box. I have tried using :Nothing,As Material, "".
I added them via
Me.combobox1.AddItem ("As Material")
I am using Inv 2008 Sp1, has anyone been able to do this yes
The easiest solution is to add "As Material" as one of the choices in your
combo box and then special case in your combo box event to check to see if
the selected item is "As Material" and set it to the renderstyle of the
material as you already know. For all other cases you can just use the
selected name.
Brian Ekins
Autodesk Inventor API
