Add-in doesn´t load - Help
HI everyone!
I have made a add-in that is not loading.
I have made the following class:
Option Explicit
Implements ApplicationAddInServer
Dim oapp As Inventor.Application
Private WithEvents MyAppEv As ApplicationEvents
Private WithEvents oButtonDef As ButtonDefinition
Private Sub ApplicationAddInServer_Activate(ByVal AddInSiteObject As Inventor.ApplicationAddInSite, ByVal FirstTime As Boolean)
' Save a reference to the Application object.
Set oapp = AddInSiteObject.Application
Set MyAppEv = oapp.ApplicationEvents
Dim oIcon1 As IPictureDisp
Set oIcon1 = LoadPicture(App.Path & "\SplitTable.ico")
Set oButtonDef = oapp.CommandManager.ControlDefinitions.AddButtonDefinition("copia0", "{040B2B94-42B9-4089-ADF4-84A67BBB9E9D}", "copia0app", "copia0app1", oIcon1, oIcon1)
If FirstTime = True Then
'create a new toolbar
Dim oCommandBar As CommandBar
Set oCommandBar = oapp.UserInterfaceManager.CommandBars.Add("copia0", "copia00ToolbarIntName", , "{040B2B94-42B9-4089-ADF4-84A67BBB9E9D}")
'add the buttons to the toolbar
oCommandBar.Controls.AddButton oButtonDef
'make the toolbar visible
oCommandBar.Visible = True
End Sub
Private Property Get ApplicationAddInServer_Automation() As Object
Set ApplicationAddInServer_Automation = Nothing
End Property
Private Sub ApplicationAddInServer_Deactivate()
If Form1.Visible = True Then
Unload Form1
oButtonDef.Delete
Set oButtonDef = Nothing
Set oapp = Nothing
End Sub
Private Sub ApplicationAddInServer_ExecuteCommand(ByVal CommandID As Long)
End Sub
Private Sub oButtonDef_OnExecute(ByVal Context As Inventor.NameValueMap)
Form1.Show
End Sub
Then i have made the regsvr32 command
and i add the following to the registry:
REGEDIT4
[HKEY_CLASSES_ROOT\CLSID\{040B2B94-42B9-4089-ADF4-84A67BBB9E9D}]
@="Clona assemblys"
[HKEY_CLASSES_ROOT\CLSID\{040B2B94-42B9-4089-ADF4-84A67BBB9E9D}\Description]
@="Clona e renomeia Assemblys"
[HKEY_CLASSES_ROOT\CLSID\{040B2B94-42B9-4089-ADF4-84A67BBB9E9D}\Implemented Categories\{39AD2B5C-7A29-11D6-8E0A-0010B541CAA8}]
[HKEY_CLASSES_ROOT\CLSID\{040B2B94-42B9-4089-ADF4-84A67BBB9E9D}\Required Categories]
[HKEY_CLASSES_ROOT\CLSID\{040B2B94-42B9-4089-ADF4-84A67BBB9E9D}\Required Categories\{39AD2B5C-7A29-11D6-8E0A-0010B541CAA8}]
[HKEY_CLASSES_ROOT\CLSID\{040B2B94-42B9-4089-ADF4-84A67BBB9E9D}\Settings]
"LoadOnStartUp"="1"
"Type"="Standard"
"SupportedSoftwareVersionGreaterThan"="9.."
When i go to tools->add-ins in the add-in manager the load behavior is startup/unloaded, i try to make load in the add-in manager, but this is not working too.
Then i go to tools->customize->commands->add-ins and the icon was not loaded.
Can someone help me to understand what is wrong here?
Thanks.
The arguments to the AddButtonDefinition aren't correct. Look at the online
help for the description of the arguments and some of the sample add-ins for
examples.
Brian Ekins
Autodesk Inventor API
