Shortcut for Save All and Close All
Hi, do you know two shortcuts (button, buttons combination, iLogic codes) to execute:
1) the command "Save All":
2) and the command "Close All":
so that, for command "Close All", Inventor automatically sets the option "Prompt only once per operation" when the following window appears:
and Inventor automatically chooses "Yes to All" in the following window:
clutsa
So the code for Save all And close all looks something like this.
Dim app As Inventor.Application = ThisApplication
saveCmd = app.CommandManager.ControlDefinitions("AppSaveAllCmd")
closeCmd = app.CommandManager.ControlDefinitions("AppCloseAllCmd")
saveCmd.Execute
closeCmd.Execute
As for the settings you can try your Application Options>Prompts>"Do you want to save the file on close?" to "Once per Operation" and Application Options>Save>"Do not list referenced files that default to 'No' in the Save dialog"
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
Hi @clutsa, sorry for delay, thank you, it works! But how to know the name of all Inventor commands, like "AppSaveAllCmd" or "AppCloseAllCmd"? Does exist a iLogic help guide about them?
Thank you
bradeneuropeArthur
Read this
https://forums.autodesk.com/t5/inventor-customization/available-api-commands/m-p/7784864/thread-id/8...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Hi @bradeneuropeArthur, good to know, thank you!
Regards
