Sheets - View Label descriptions (Code)
NachoShaw
Advisor Advisor
Message 1 of 16
NachoShaw
i could never figure out why Inventor isnt more intuitive when it comes to sheets. We all need to place a view of either the Front, Side, Top or Iso etc and yet, the settings allow us to merely place a single word for base views & projected views. This frustrated me so i made a tool and i have added it below for anyone who would find this useful.
There is a small draw back. it doesnt dynamically add the scale to the view label ( <SCALE> ) as i cant find a way to include that in my code. Nevertheless though, you only have to click your button once and it updates ayway so its no major draw back.
What it does
it loops through all of the views on the drawing and changes or adds the vew label to the view that it is i.e. Front, Left, Right etc etc. it adds the scale underneath. If the view is a section or a detail, it will be skipped.
Code
Public Sub GetTheViews()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oSheets As Sheets
Dim oSheet As Sheet
Dim oViews As DrawingViews
Dim oView As DrawingView
Dim iView As Integer
Dim iViewText As String
Dim Ret As Long
Ret = MsgBox("Would you like to add the Scale too?", vbYesNo)
Set oSheets = oDoc.Sheets
        For Each oSheet In oSheets
            Set oViews = oSheet.DrawingViews
                For Each oView In oViews
                    iView = oView.Camera.ViewOrientationType
                    Select Case iView
                        Case 10764
                            iViewText = "FRONT ELEVATION"
                        Case 10763
                            iViewText = "CUSTOM VIEW"
                        Case 10754
                            iViewText = "PLAN ELEVATION"
                           Case 10757
                            iViewText = "BOTTOM ELEVATION"
                        Case 10758
                            iViewText = "LEFT ELEVATION"
                        Case 10755
                            iViewText = "RIGHT ELEVATION"
                        Case 10756
                            iViewText = "BACK ELEVATION"
                        Case 10759
                            iViewText = "TOP RIGHT ISO VIEW"
                        Case 10760
                            iViewText = "TOP LEFT ISO VIEW"
                        Case 10761
                            iViewText = "BOTTOM RIGHT ISO VIEW"
                        Case 10762
                            iViewText = "BOTTOM LEFT ISO VIEW"
                        Case Else
                    End Select
                    Select Case oView.ViewType
                        Case 10502 To 10503
                        'do nothing to skip sections & details
                        Case Else
                        Select Case Ret
                            Case 6
                                oView.Label.FormattedText = iViewText & vbCrLf & "SCALE - " & GetFraction(oView.Scale)
                                oView.ShowLabel = True
                                oView.Label.ConstrainToBorder = True
                            Case Else
                        End Select
                    End Select
                Next
        Next
End Sub
Function GetFraction(ByVal Num As Double) As String
    If Num = 0# Then
        GetFraction = "None"
    Else
        Dim WholeNumber As Integer
        Dim DecimalNumber As Double
        Dim Numerator As Double
        Dim Denomenator As Double
        Dim a, b, t As Double
        WholeNumber = Fix(Num)
        DecimalNumber = Num - Fix(Num)
        Numerator = DecimalNumber * 10 ^ (Len(CStr(DecimalNumber)) - 2)
        Denomenator = 10 ^ (Len(CStr(DecimalNumber)) - 2)
        If Numerator = 0 Then
            GetFraction = WholeNumber
        Else
            a = Numerator
            b = Denomenator
            t = 0
            While b <> 0
                t = b
                b = a Mod b
                a = t
            Wend
            If WholeNumber = 0 Then
                GetFraction = CStr(Numerator / a) & ":" & CStr(Denomenator / a)
            Else
                GetFraction = CStr(WholeNumber) & " " & CStr(Numerator / a) & ":" & CStr(Denomenator / a)
            End If
        End If
    End If
End Function
 simply add the code to a new module and add the button to the ribbon using the Customisation toolbar. I will make this into an addin but i need to finish my iProperties tool first along with a few other neat tools 🙂
there is a quick video demo attached to see it in action
Nigel
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Replies (15)
Message 2 of 16
brendan.henderson
Nigel, this looks awesome. Thanks for the effort.
I added it and on running it and selecting YES to the scale question I get an Run-time error '6': Overflow and when I debug its the line shown below :-
I don't know much about VB so I can't track down what the problem is.
FYI I work in metric so I don't know if this is a problem with the scales.
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Message 3 of 16
NachoShaw
Hi
Yeah I get the same error on the same line. I work in metric too as in 1:10 - 1:20 etc. when I collect the scale from inventor, it comes as a decimal which is why I have the conversion function. I have slightly updated my code to now include the sections and detail views which is much better. I'll see if I can improve the scale conversion or if I can collect the actual scale that the view is initially placed in.
Any updates will be put here.
I did the code because it takes too long to manually change or add the view itself and relying purely on the inventor part of setting a generic name isn't enough for my clients.
Glad you like the code 🙂
Nigel
Nacho
Message 4 of 16
NachoShaw
Hi
updated code that now collects the correct view scale based on whatever was selected or set in the place view dialog box. the conversion function is no longer required. If i can find the actual stored view value, i'll revise the code again and post but this updated code works great 🙂
Public Sub SetViewLabels()
   On Error GoTo SetViewLabels_Error
    Dim oSheet As Sheet
    Dim Ret    As Long
            Select Case iView
                Case 10764
                Case 10763
                    iViewText = "ISOMETRIC VIEW"
                Case 10754
                Case 10757
                Case 10758
                Case 10755
                Case 10756
                Case 10759
                Case 10760
                Case 10761
                Case 10762
                Case Else
            End Select
                Case 10503
                    'TREAT THE SECTION TEXT TO LINE UP CORRECTLY
                    iViewText = "SECTION '<DrawingViewName/> - <DrawingViewName/>'"
                Case 10502
                    iViewText = "DETAIL '<DrawingViewName/>'"
                Case 10499
                    iViewText = "AUXILIARY VIEW - '<DrawingViewName/>'"
                Case Else
            End Select
            Select Case Ret
                Case 6
                    oView.Label.FormattedText = iViewText & vbCrLf & "SCALE - " & oView.ScaleString
                Case Else
            End Select
        Next
    Next
   On Error GoTo 0
   Exit Sub
SetViewLabels_Error:
    MsgBox "Error " & Err.Number & " (" & Err.Description & ") in procedure SetViewLabels of Module mod_GetViewNames"
End Sub
Nacho
Message 5 of 16
NachoShaw
Hi
i have uploaded a video to show how easy it is to use 🙂
Drawing Views Label Text
Nigel
Nacho
Message 6 of 16
brendan.henderson
Nigel, thanks for the update.
I deleted the old code and added the new. On running it I get nothing. No view pop-up asking about Scales and no view labels. I see that it's working in your video so I think the problem is at my end. I restarted Inventor to make sure the new VBA code was loaded, but still no labels when I run it. Any ideas?
Brendan Henderson
CAD Manager
Message 7 of 16
NachoShaw
Hi
As a first thought, im going to guess that you deleted ALL of the code. if that was the  case, Inventor might remove the button link in the ribbon. i would right click the ribbon and select customise. then select Macro from the dropdown in the  top left corner. select what ribbon menu you want the button to be place in (drop down menu top right)
then click the routine 'SetViewLabels' and  the click the >> button. click apply and it should work.
Usually, if you delete code, it would disassociate with the button. If your existing button is already there, remove it then re-add it.
let me know how you get on 🙂
Nigel
Nacho
Message 8 of 16
NachoShaw
Hi
Updated Code. this now changes the scale when the view is updated. This means that you only need to run the tool once to change the text 🙂
    Dim oSheet As Sheet
    Dim Ret    As Long
    Dim mBar As ProgressBar
                Select Case iView
                    Case 10764
                    Case 10763
                    Case 10754
                    Case 10757
                    Case 10758
                    Case 10755
                    Case 10756
                    Case 10759
                    Case 10760
                    Case 10761
                    Case 10762
                    Case Else
                End Select
                    Case 10503
                    Case 10502
                    Case 10499
                    Case Else
                End Select
                Select Case Ret
                    Case 6
                        oView.Label.FormattedText = iViewText & vbCrLf & "SCALE - <DrawingViewScale/>" '& oView.ScaleString
                    Case Else
                End Select
            Next
        Next
        On Error GoTo 0
        Exit Sub
End Sub
Nacho
Message 9 of 16
brendan.henderson
Nigel, you were right. I removed the button and made a new link to the macro and got better results.
If I choose NO to the pop-up about Scale then I get no view labels. I have tried both this code and the code on your other posting here and they both do the same. No view label if I select NO to the Scale question.
Here is a link to a short video of this problem.
Brendan Henderson
CAD Manager
Message 10 of 16
NachoShaw
Hi
Try this. The oView.ShowLabel = True wasn't present in the code. It's visible by default on my machine but could be turned off on yours. This is in the select case Ret where case else does everything if the message of choice is not "yes"
Let me know how you get on please
Dim oSheet As Sheet
Dim Ret As Long
Select Case iView
Case 10764
Case 10763
Case 10754
Case 10757
Case 10758
Case 10755
Case 10756
Case 10759
Case 10760
Case 10761
Case 10762
Case Else
End Select
Case 10503
Case 10502
Case 10499
Case Else
End Select
Select Case Ret
Case 6
Case Else
End Select
Next
Next
Exit Sub
End Sub
Cheers
Nacho
Message 11 of 16
GosponZ
It is working good but one question please. Is it there way in multi sheets this code to work separate on each sheet. Sometimes i do not need labels on all sheets. Thank you
Message 12 of 16
NachoShaw
Hi
Yes. You can comment out 2 lines-
For Each Sheet in oSheets
And
The 'Next' at the bottom of the page. I'm making this into a tool to make it easier to use too 🙂
Nigel
Nacho
Message 13 of 16
GosponZ
i tried but no working 😞
Message 14 of 16
NachoShaw
Ok
Let me take a look and post a single sheet version 🙂
Nigel
Nacho
Message 15 of 16
GosponZ
Smiley HappyYou are the man.
Message 16 of 16
NachoShaw
Hi
i have made a tool to suit your needs and posted it here with full instruction 🙂
http://forums.autodesk.com/t5/Inventor-Customization/New-VBA-Drawing-View-Labels-tool/td-p/4936348
Nigel
Nacho
