Sheet Names
Sheet Names
Message 1 of 28
Sheet Names
I am wanting to have my sheet names enter automatically into my titleblock, but it is not a selectable "Text Parameter" to enter.
I am currently using a "Prompted Entry" to produce the Page Name in the titleblock, but would like to use what I name the sheet.
Any way this is possible?
Replies (27)
Message 2 of 28
Are you unable to copy the sheet name to the base model iProperty?
Instead of changing the sheet names, you could name an iProperty on the model of your intended sheet name and then use that as part of your title block.
Message 3 of 28
That's a good idea, but for my assemblies, there will not be a standard sheet per model/part number.
I am simply using Architectural type of numbers like A1.0, A1.1, A1.2....ETC....
Message 4 of 28
HermJan.Otterman
Hello James,
try this (iLogic code)
Private Sub SetSheetname()
Dim oDrawDoc As Inventor.DrawingDocument = Thisapplication.ActiveDocument
' Set a reference to the drawing document.
' This assumes a drawing document is active.
' Obtain a reference to the desired border defintion.
Dim oTitleBlockDef As TitleBlockDefinition
oTitleBlockDef = oDrawDoc.TitleBlockDefinitions.Item("Sample Title Block")
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
' Check to see if the sheet already has a title block and delete it if it does.
If Not oSheet.TitleBlock Is Nothing Then
oSheet.TitleBlock.Delete()
End If
' This title block definition contains one prompted string input. An array
' must be input that contains the strings for the prompted strings.
Dim sPromptStrings(0) As String 'start counting by 0 !!!
sPromptStrings(0) = oSheet.Name 'if there is only one promped entry
'sPromptStrings(1) = "String 2"
' Add an instance of the title block definition to the sheet.
Dim oTitleBlock As TitleBlock
oTitleBlock = oSheet.AddTitleBlock(oTitleBlockDef, , sPromptStrings)
End Sub
most of it comes from the Inventor help.
important is that you addres ALL prompted entries, so in this case there is only one.
if you have more, for example 2 then start counting by zero, so you have two lines: (0 and 1)
this will work for the active sheet, if you have more than one, make a for each loop to go through all sheets.
put this rule on a befor save trigger
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Message 5 of 28
I don't know if this will help you or not, but the first line is to simply get the sheet name, the second line is to get the base model name, and the third line is to change an iProperty to what you want in the model.
oSheet=ThisApplication.ActiveDocument.ActiveSheet.Name
model = ThisDrawing.ModelDocument.DisplayName & ".iam"
iProperties.Value(model,"Project", "Project") = oSheet
 With what you want to do it sounds like you'll need to do some restructuring to make it work right.  I'm happy to help more if I can.
Message 6 of 28
where do I enter this first line?
I haven't entered any custom code as of yet.
Message 7 of 28
tolgay.hickiran
small tip for you,
Everytime you see a code Thisapplication.ActiveDocument, you immediately know that this bit of the code would work on the same document that you want to do some changes, in this case, your drawing
Some worthwhile ideas
Copy Design should rename ilogic Rules too!
Why Nastran In-CAD doesn't have an SDK?IMPLEMENTED!
Tolgay Hickiran
Founding Partner
SignatureSignature
website
emailskypelinkedinyoutubeemail
Message 8 of 28
Go to Manage > iLogic > iLogic Browser
Then open the Rules tab and right click in the empty space to add a rule.
It's helpful if you know some Visual Basic but Inventor is pretty forgiving with the code.  Once you hit OK the rule will run.  To get the rule to work in any drawing, you'll have to create an external rule.
Message 9 of 28
HermJan.Otterman
Hello James,
what Inventor version are you using?
here is an Inventor 2015 drawing with three sheets.
in it is an iLogic rule that will set the sheetname in the title block (on all sheets, code is a little changed)
look at my screencast: http://autode.sk/2knOzER
Herm Jan
Message 10 of 28
NachoShaw
Maybe this will help. I posted it a while ago. This is based on the Display Name but you can change it to any iProperty you want. It basically does the opposite of you are doing but the result is the same.
Edit the iProperty for the Part / Assembly
Change the browser name to that iProperty value
Thread can be found Here
Code:
Public Sub ReNameSheets()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim osheets As Sheets
Set osheets = oDoc.Sheets
Dim oSheet As Sheet
Set oSheet = oDoc.ActiveSheet
Dim defSheetLabel As String
defSheetLabel = oDoc.SheetSettings.SheetLabel
Dim sCount As Integer
For Each oSheet In osheets
    On Error Resume Next
    'oSheet.Activate
    Dim oDrawingView As DrawingView
    Set oDrawingView = oSheet.DrawingViews(1)
    omodelname = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument.DisplayName
oSheet.Name = omodelname & " - " & defSheetLabel
'If you only want the Display Name, Comment out the above line & Uncomment the below line
'oSheet.Name = omodelname
Next
Reset the sheets to the default 'Sheet'
Public Sub ResetSheets()
Dim oSheet As Sheet
    'oSheet.Activate
oSheet.Name = defSheetLabel
Next
Video Here
Hope that helps
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Message 11 of 28
HermJan.Otterman
if you would use iPorperties than you would need an iProperty for every sheet.
I don't say it is not possible but you would get many iProperties, if you have many sheets..
Herm Jan
Message 12 of 28
@HermJan.Otterman
I know this is an old post but this page got me super close to my goal! thank you
How do I have it so the sheet name in the title block won't show the sheet number (:2) at the end?
Message 13 of 28
HermJan.Otterman
Hello Ryan,
here is how you can get rid of the :x
positionOfDubbleDot = strings.InStrRev(oSheet.Name,":")
Length = Len(oSheet.Name)
stringYouNeed = Left(oSheet.Name, Length-(Length-positionOfDubbleDot)-1)
Herm Jan
Message 14 of 28
thank you,
I'm new to the more document driven code, where would I place those lines in my code?
'https://forums.autodesk.com/t5/inventor-customization/sheet-names/td-p/6824616
Dim oDrawDoc As Inventor.DrawingDocument = ThisApplication.ActiveDocument
	oTitleBlockDef = oDrawDoc.TitleBlockDefinitions.Item("Standard (WB)")
Dim oSheet As Sheet
Dim oSheets As Sheets = oDrawDoc.Sheets
'oSheet = oDrawDoc.ActiveSheet
For Each oSheet In oSheets
	End If
Next
Message 15 of 28
@HermJan.Otterman
I have updated my code slightly, but I still struggle in figuring out where to put the lines you sent me on Friday.
Any help would be appreciated!
Sub main ()
	Rename_SheetName ()
	Create_PageNo()
End Sub
Function Rename_SheetName
	Dim oSheet As Sheet
	Number = InputBox("Input initial number", "Rename sheets", "1")
	Letter = "A"
	FirstSheet=True
	For Each oSheet In oDoc.Sheets
		If FirstSheet = True
			oSheet.Name = Number
			FirstSheet = False
		Else
		oSheet.Name=Number + Letter
		Letter = Chr(Asc(Letter) + 1)
		End If
	Next
End Function
Function Create_PageNo
	Dim oSheet As Sheet
		End If
	Next
End Function
Message 16 of 28
i was learning i logic,for my understanding, this can be use with single prompted entry. can it be use with multiple prompted entry?
Message 17 of 28
HermJan.Otterman
Hello RSeufzer,
this code should work:
Sub Main()
        oDrawDoc = ThisApplication.ActiveDocument
        Rename_SheetName(oDrawDoc)
        Create_PageNo(oDrawDoc)
    End Sub
    Sub Rename_SheetName(ByVal oDrawdoc As Inventor.DrawingDocument)
        Dim oSheet As Sheet
        oSheet = oDrawdoc.ActiveSheet
        Dim Number As String = InputBox("Input initial number", "Rename sheets", "1")
        Dim Letter As String = "A"
        Dim FirstSheet As Boolean = True
        For Each oSheet In oDrawdoc.Sheets
            If FirstSheet = True Then
                FirstSheet = False
            Else
                oSheet.Name = Number + Letter
            End If
        Next
    End Sub
    Sub Create_PageNo(ByVal oDrawdoc As Inventor.DrawingDocument)
        oTitleBlockDef = oDrawdoc.TitleBlockDefinitions.Item("Standard (WB)")
        Dim oSheet As Sheet
        Dim oSheets As Sheets = oDrawdoc.Sheets
            End If
            ' remove the ":1"
            Dim positionOfDubbleDot As Integer = Strings.InStrRev(oSheet.Name, ":")
            Dim Length As Integer = Len(oSheet.Name)
            Dim stringYouNeed As String = Strings.Left(oSheet.Name, Length - (Length - positionOfDubbleDot) - 1)
            sPromptStrings(0) = stringYouNeed 'if there is only one promped entry
        Next
    End Sub
Herm Jan
Message 18 of 28
HermJan.Otterman
That is correct,
the example here is with one Prompted entry, but in the code is also for a second Prompted entry the code as comment,
you can copy that for aditional prompted entries.
Herm Jan
Message 19 of 28
Can you attach the example that contain 2 or more prompted entries.it more easy to understand how the code function.....thanks you
Message 20 of 28
Where does the code
positionOfDubbleDot = Strings.InStrRev(oSheet.Name,":")
go to get rid of the :2 in the sheet name? I have tried to use the original code you put out there for inserting sheet names into the title block. Also, there is no trigger to make it happen or it's not working properly.
