Sheet Metal Flat Pattern only showing smaller "part" in flat pattern view
Shag_Bore
Shag_Bore
I have sheet metal rule that takes the flat pattern, organizes the flat extents and then concatenates a custom part number. This helps me group my items on my parts lists.
Works great but on parts like this, where there is a cut, the flat pattern reports the smaller, interior part of the part. There is an additional part behind the cutout(not shown), that gets laminated to the inside face, which secures the smaller interior sheet metal circle in position, (it doesn't actually float there haha)
is there a rule to manipulate the flat pattern to grab the sheet extents and not the cut out? I have attached the part, I am using Inv, 2016, I am thinking of maybe creating a custom parameter, but I am not sure how to map it to the actual flat pattern initially.
here is my rule I use to create the custom part number.
'FLAT PATTERN DIMS
TEMP_EXTENTS_LENGTH = SheetMetal.FlatExtentsLength
TEMP_EXTENTS_WIDTH = SheetMetal.FlatExtentsWidth
x = TEMP_EXTENTS_LENGTH
y = TEMP_EXTENTS_WIDTH
'ENSURE LONGER DIMENSION IS DEFINED AS LENGTH
If x > y Then
ElseIf x < y Then
    EXTENTS_LENGTH = SheetMetal.FlatExtentsWidth
    EXTENTS_WIDTH = SheetMetal.FlatExtentsLength
'PART NUMBER NAMING
extlength=EXTENTS_LENGTH
extwidth=EXTENTS_WIDTH
extarea=AREA
'convert values to fraction
oW = RoundToFraction(extlength, 1/16, RoundingMethod.Round)
oL = RoundToFraction(extwidth, 1/16, RoundingMethod.Round)
'create custom part number
iProperties.Value("Project", "Part Number") = iProperties.Value("Project", "Cost Center")&" - LENGTH " & oW & " - WIDTH " & oL
The only way I can think of to do this without iLogic is to perform the cuts fully(leave no circle), then do a reverse of the same cuts (leave only the circle) and make those parts phantom so they don't count as parts, but this is still extra .ipt's and time.
thanks!
Sean
Sean Farr
Product Designer at Teksign Inc.
Inventor 2016 SP1
Dell Precision 3660
i7-12700 @ 2.40GHz-4.90GHz
32GB DDR5 4400MHz RAM
NIVDIA RTX A2000 6GB
bradeneuropeArthur
You are still using 2016 of Inventor, isn't it?
I have opened the file and see indeed that the Flat Pattern shows the smaller part.
I am on 2023 of Inventor and created the Flat Pattern new and now it shows the bigger part.
Seems to be solved in later releases...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Shag_Bore
Thank you, I wasn't expecting this to be an issue due to current version. I will add this feature to my "reason to upgrade" list.
For now I will do a "full" cut/emboss on the panels, then create an inverse of the same part, make it phantom as not to affect the BOM, and add it to the assembly to get the finished results.
Thanks!
Sean
Sean Farr
Inventor 2016 SP1
Dell Precision 3660
b.mccarthy
I have done something similar using model states. When you upgrade, maybe look into that workflow.
HTH
