Sheet metal Browser Folders
Curtis_Waguespack
Consultant Consultant
Curtis_Waguespack
Doe anyone know how to access the Folded Model node in a sheet metal part, or how to find browser folders in a sheet metal part?
When I run this bit of code it comes back empty when looking for browser folders when the part is a sheetmetal part.
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
'For Each Pane In oDoc.BrowserPanes
'	oMsg = oMsg & vbLf & "Pane Name: " & Pane.name
'Next
'oMsg = oMsg & vbLf & "--------"
Dim oPane As BrowserPane
oPane = oDoc.BrowserPanes.Item("Model")
Dim oTopNode As BrowserNode
oTopNode = oPane.TopNode
oMsg = oMsg & vbLf & "Folder Count: " & oPane.TopNode.BrowserFolders.Count
For Each oFolder In oPane.TopNode.BrowserFolders
	oMsg = oMsg & vbLf & "Folder Name: " & oFolder.name
Next
MessageBox.Show(oMsg, "ilogic")
standard part
same part converted to sheet metal
bradeneuropeArthur
Dim oDoc As Inventor.PartDocument
Dim c As Inventor.SheetMetalComponentDefinition = oDoc.ComponentDefinition
'Next
oMsg = oMsg & vbLf & "Folder Count: " & oPane.TopNode.BrowserNodes.Item(1).FullPath
For Each oFolder In oPane.TopNode.BrowserNodes.Item(1).BrowserFolders
Next
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
or even Better:
'Next
oMsg = oMsg & vbLf & "Folder Count: " & oPane.TopNode.BrowserNodes.Item("Folded Model").FullPath
For Each oFolder In oPane.TopNode.BrowserNodes.Item("Folded Model").BrowserFolders
Next
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Curtis_Waguespack
Thanks!
I'm certain I tried getting the 'Folded Model' node by name, but I must have had something not right 🙃
Here's what I ended up with in case it helps someone in the future.
Dim oTargetNode As BrowserNode
If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
	oTargetNode = oPane.TopNode.BrowserNodes.Item("Folded Model")
Else
	oTargetNode = oTopNode
oMsg = oMsg & vbLf & "Folder Count: " & oTargetNode.BrowserFolders.Count
For Each oFolder In oTargetNode.BrowserFolders
Next
