Sheet Metal Bend FrontFaces and BackFaces Not Working?
danmorick
danmorick
Hi there.  I have an iLogic rule that has been working fine until recently and I can't figure out why it now has a problem.  It seems to be with Bend.FrontFaces or Bend.BackFaces.  The troublesome part of my code is below.  Does anyone see anything wrong with what I have, or know of something that happened with Inventor 2016 to make it not work?  Again, this used to work perfectly well.
Thanks!
SyntaxEditor Code Snippet
Sub Main()
Dim oApp As Inventor.Application = ThisApplication
If oApp.ActiveDocument.Subtype <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then 'not sheet metal document
Exit Sub
End If
oApp.SilentOperation = True
Dim oPartDoc As PartDocument = oApp.ActiveDocument
Dim oSMDef As SheetMetalComponentDefinition
oSMDef = oPartDoc.ComponentDefinition
Dim oFeatures As SheetMetalFeatures = oSMDef.Features
Dim oFace As Face
Dim oBend As Bend
Dim oBends As BendsEnumerator = oSMDef.Bends()
Dim i As Integer = 0
'Get a valid face for unfolding and flat sketch
For i = 1 To 80
oPartDoc.SelectSet.Clear
oFace = oSMDef.SurfaceBodies.Item(1).Faces.Item(i)
    If oFace.SurfaceType = 5890 Then
        oPartDoc.SelectSet.Select(oFace)
        Try
        oFeatures.UnfoldFeatures.Add(oFace)
        oApp.CommandManager.ControlDefinitions("AppUndoCmd").Execute
        Exit For
        Catch
        End Try
    End If
Next
    If i=80 Then 'failed to find a good face
    MessageBox.Show("Couldn't unfold.", "Failure")
    Exit Sub
    End If
System.Threading.Thread.CurrentThread.Sleep(100)
Try
oSketch = oSMDef.Sketches.Add(oFace, False) 'Do not project face edges
Catch
Exit Sub
End Try
Dim oBackFaces As Faces
Dim oFrontFaces As Faces
oSketch.Edit
For Each oBend In oBends
    oBackFaces = oBend.BackFaces
    oFrontFaces = oBend.FrontFaces
'It doesn't make it to here!
HermJan.Otterman
hello Danmorick,
you didn't declare osketch.
add the line :  (before the try-catch)
Dim oSketch As PlanarSketch
and it will go
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
danmorick
Herm Jan,
Thanks very much for the reply.  I actually do have that in my code; apparently I deleted it out accidentally when I was clearing out unimportant stuff to paste here.  I apologize.  Through my testing I've found that it definitely errors on
 and similarly on
But what's weird is that last year it worked consistently.  In Inventor 2016 it seems like something changed internally and this code no longer works.
HermJan.Otterman
well, with the line I send you, the code runs on my machine until the last line, with no errors.
so maybe other code is not right??
Herm Jan
