'Run All Rules' API command
Does anybody know what the API command is for 'Run All Rules' in iLogic?
MechMachineMan
From what I can tell in control definitions, there is none.
however, something like this will work assuming you are connected to the addin in vb.net
https://forums.autodesk.com/t5/inventor-customization/ilogic-api-documentation/td-p/6785772
iLogicAuto = iLogicVb.Automation
'MsgBox(iLogicAuto.iLogicRules.Count)
For Each oRule In iLogicAuto.Rules(ThisApplication.ActiveEditDocument)
       MsgBox(oRule.Name)
	   iLogicAuto.RunRuleDirect(oRule)
Next
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
@MechMachineMan
Thanks MechMachineMan, this only runs all the rules in the currently open document, not in its sub-components also, is it possible to adjust it to do that?
I'm guessing its ThisApplication.ActiveEditDocument that needs to be changed?
