Setting up MM hex bolts with I logic. I have a question
corey_danielson
corey_danielson
I am trying to follow McMaster Carr for sizes, the MM are fully threaded until about 60 mm long, then they offer fully and partial threaded. I have a parameter called thread, with a pull-down menu with partial and full.
LENGTH parameter is length of bolt.
THREADLENGTH parameter is for the thread length
I want user to be able to select partial or full, but only when length selected in form is larger than is set in the rules
If LENGTH <= 60 Then
THREADLENGTH = LENGTH
Else If LENGTH >= 60 Then
MessageBox.Show("SELECT FULL OR PARTIAL THREADS", "Thread Choice")
THREAD = InputBox("FULL")
Else If InputBox("PARTIAL")
	THREADLENGTH = 18
bradeneuropeArthur
Could you not better create a Content Center Family?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
