Setting Dimension TextPoint Location using iLogic
ad64
ad64
I can't seem to get Inventor to locate a Sketch Dimension label using TextPoint in Inventor 2014.
Here's some simple test code I've been trying.
For Each oDim In ThisDoc.Document.ComponentDefinition.Sketches(2).DimensionConstraints
        oDim.TextPoint.X = 3
        oDim.TextPoint.Y = 3
        MsgBox(oDim.TextPoint.X & vbCrLf & oDim.TextPoint.Y)
Next
Why doesn't this move the dimension to 3, 3?
Steve
Hi ,
Please use the below code .it is already there in Inventor help file.So i modified some lines to meet your requirement.I hope this helps....
Public Sub StartSketchEdit()
' Set a reference to the Sketches collection. This assumes
' that a part document containing a sketch is active.
Dim oSketches As PlanarSketches
Set oSketches = ThisApplication.ActiveDocument.ComponentDefinition.Sketches
' Get the sketch named "Sketch1".
On Error Resume Next
Dim oSketch As PlanarSketch
Set oSketch = oSketches.Item("Sketch1")
oSketch.Edit
Dim oDimConsrts As DimensionConstraints
Set oDimConsrts = oSketch.DimensionConstraints
Dim oDimCons As DimensionConstraint
Dim oDimPosition As Point2d
For Each oDimCons In oDimConsrts
Set oDimPosition = oDimCons.TextPoint
oDimPosition.X = 3
oDimPosition.Y = 3
oDimCons.TextPoint = oDimPosition
Next
oSketch.ExitEdit
If Err Then
MsgBox "A Sketch named ""Sketch1"" must exist."
Exit Sub
End If
On Error GoTo 0
End Sub
