Message 1 of 1
Modifying clearance.xls
I would like to modify the clearance.xls hole table to reflect our compnay standard for press fit and slip fit holes for dowels. I can create teh new tab and enter the base hole sizes fine. I need to know if it is possible to pull the hole tolerance from this spreadsheet as well. Any help woudl be appreciated.
If it is not configurable through here, then is there a better way to accomplish this. The final outcome is a easy process to click a press fit hole size that does not require editing of the hole parameters in teh dialog box.
Tony
