Setting and indicating the units in drawings
I am using Inventor to design a mask for a chip the dimensions of which naturally lend to working in micrometres or nanometres.
Whilst I have been able to set the units when designing parts to micrometres, I am unable to do the same in the drawings.
Please assist!
Matthew
When using iLogic or VBA Inventor always uses cm as its units. I always hard coded the conversion from cm to whatever myself.
Here is a link with more info. It's old (2012) but the units information near the top is still relevant.
http://adndevblog.typepad.com/manufacturing/2012/07/unitsofmeasure-object-and-example.html
bshbsh
You want to change your drawing dimension style. Like this.
Thank you for your response.
The link you posted hasn't proved useful unfortunately.
I would expect the units specified in
Tools > Documents Settings > Units
to apply universally. Why are the drawing units different, and how do I specify them? I am using Autodesk Inventor 2017.
