Create as new part from an occurance
JorisSteurs1246
Message 1 of 8
JorisSteurs1246
My final goal  is to replace all leaf occurrences with a copy that gets the filename as the Part Number of this occurance.
I'm not sure if I have to make new parts first and then replace them , or that I can do an equivalent in iLogic to the " save and replace component" command.
Anyhow this is the code I have so far.
I 'm producing the correct filenames already but it fails to do a "save as" or a "replace"
SyntaxEditor Code Snippet
fmgr = ThisApplication.Filemanager
For Each file In fmgr.files
doc = ThisApplication.Documents.ItemByName (file.fullfileName)
compdef = doc.ComponentDefinition
Dim newname As String
If (doc.documenttype = 12291) Then ' only do this for assembly or subassembly
 For Each occ In compdef.Occurrences
    If (occ.definition.type =83886592) Then ' only do this for part
        Try
               occ.Name =  iProperties.Value(occ.Name,"Project", "Part Number")
              newname = iProperties.Value(occ.Name,"Project", "Part Number") & ".ipt"
               MessageBox.Show("I found variable: " & newname , "Info")
              'occ.Replace( newname , True)
                occ.SaveAs (newname , True)
           Catch
        MessageBox.Show("error")
        End Try
 Next occ
Next file
Replies (7)
Message 2 of 8
Jef_E
Maybe this post has the answer you are looking for?
http://forums.autodesk.com/t5/inventor-customization/vba-save-and-replace-all-instances-of-a-part/td...
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Message 3 of 8
JorisSteurs1246
this sample uses the same line as I tried
opartdoc.SaveAs(NewFilePath, True)
in that sample it is not inside a loop
in my loop that line gives an error.
Joris.
Message 4 of 8
Jef_E
What is the error message? Can you take a screenshot of the messagebox where the newname is shown?
Inventor 2014 SP2
Message 5 of 8
JorisSteurs1246
with the Try and Catch in my code  it jumped to my own error message.
When I  leave the Try and Catch out to trigger inventor's error, I get
when trying  : occ.Replace( newname , True)
gives me  error 1 and 2  ( attached)
when trying  : occ.SaveAs (newname , True)
gives error 3 and 4  ( attached)
(will have to make another post or the fourth  attachment)
Message 6 of 8
JorisSteurs1246
here is attachment 4  (looks as only 3 attachments were allowed)
Message 7 of 8
Jef_E
You can't saveas a occurrence, you can only save a document
' Save-As the document
Dim oNewDoc As Document
oNewDoc = occ.Definiton.document.SaveAs(newname, True)
' Replace the occurrence with the new document
occ.Replace(oNewDoc.FullFileName, True)
But, I was thinking about this process you describe and why would you want to do this? Why would you want to save and replace all occurrences?
Inventor 2014 SP2
Message 8 of 8
JorisSteurs1246
Hi Jef
Thanks for looking into this,
I've cut away some of the other code to get to the root of the problem.
I tried to do a Save As  with your suggestion,
But the code below still gives me the error as attached.
the reason for this code:
Before releasing an Assembly , I set all the part numbers for every part with a logical order and I want to have all the file names the same as the part numbers.
In order to have some consistency in the numbering I can do that only at the end of the project, and it is quite a bit of work.
Sometimes a new version with new partnumbers have to be made and then it starts all over again.. so basicaly wasting a good amount of time.
I thought this would be a perfect subject to  submit to some automation.
  'check this file is an assembly
        Dim doc As Document = ThisApplication.ActiveDocument
        If doc.DocumentType = kPartDocumentObject Then
            MessageBox.Show("This rule can only be run in an assembly file!", "Stopped")
            Return
               oNewDoc = occ.Definiton.Document.SaveAs(newname, True)
 Next
