VBA Save and replace all instances of a part
pball
Mentor Mentor
Message 1 of 9
pball
I'm trying to make a script to replace all instances of a part/assembly in an assembly with a new copy of that file. So I'm trying to make an improved version of the "save and replace component" feature since it will only replace one part. I've created an ideastation post to have "save and replace component" be able to replace all instances of the part you replacing, but I want this feature in the mean time.
So far the script prompts you to select a part, enter a few filename, and does a check on the new file name. I need help with saving a new copy of the selected part and replacing all instances of the original part in the assembly. Is there a simple way to replace all instances or will it require a loop through all components and checking the filename then replacing ones that match, if so that's something I should be able to do. Thanks.
Public Sub Save_Replace_All()
    'Checks if open document is assembly
    If (ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject) Then
        MsgBox "This is NOT an assembly document!", vbExclamation
        Exit Sub
    Dim oPart As ComponentOccurrence
    Dim opartdoc As Document
    Dim oPartdoc2 As Document
    Dim NewFileName As String
    Dim NewFilePath As String
    Set oPart = ThisApplication.CommandManager.Pick(kAssemblyOccurrenceFilter, "Select the part to save and replace all.")
    Set opartdoc = oPart.Definition.Document
    NewFileName = InputBox("What is the new file name for " & filename_noext(opartdoc.FullFileName) & "?", "New File Name", filename_noext(opartdoc.FullFileName))
    NewFilePath = ThisApplication.FileLocations.Workspace & "\" & NewFileName & "." & file_ext(opartdoc.FullFileName)
    If (fileExists(NewFilePath)) Or (NewFileName = "") Then
        MsgBox ("Error! Either file exists or no filename given")
        Exit Sub
    'needs to save a copy of opartdoc as newfilepath, found this in another script but the script editor doesn't like it
    opartdoc.SaveAs(newfilepath,False)
'This replaces the selected part but I need to replace them all Call oPart.Replace(NewFilePath, False) End Sub
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
Replies (8)
Message 2 of 9
You only have to set the second parameter to TRUE. That's all.
oPart.Replace(NewFilePath, True)
Message 3 of 9
pball
I still get an error from the vba editor.
Compile error:
Expected: =
Message 4 of 9
pball
Well I finally got everything working. Found out how to save a copy of the selected part/assembly and replace all instances in the active assembly. So it won't affect sub-assemblies or parent assemblies if you are editing a sub-assembly.
        Exit Sub
        Exit Sub
    Call opartdoc.SaveAs(NewFilePath, True)
    Dim fd As DocumentDescriptor
    For Each fd In ThisApplication.ActiveEditDocument.ReferencedDocumentDescriptors
        If (fd.FullDocumentName = opartdoc.FullFileName) Then fd.ReferencedFileDescriptor.ReplaceReference (NewFilePath)
    Next
End Sub
Message 5 of 9
Get a compile error:
Sub or Fnction not defined
filename_noext
Message 6 of 9
And fileExists
I don't have your function in the project. But it still works if I delete functions.
It will be better if it uses ThisApplication.CreateFileDialog.
Message 7 of 9
pball
Well here are the couple of functions I use in this script if anyone is interested.
Also apparently that is my old version, since I did add a file save dialog afterwards.
    On Error GoTo err:
        Exit Sub
    If (oPart Is Nothing) Then Exit Sub
   'Create a new FileDialog object.
    Dim oFileDlg As FileDialog
    Call ThisApplication.CreateFileDialog(oFileDlg)
    'check file type and set dialog filter
    If opartdoc.DocumentType = kPartDocumentObject Then
        oFileDlg.Filter = "Autodesk Inventor Part Files (*.ipt)|*.ipt"
    ElseIf opartdoc.DocumentType = kAssemblyDocumentObject Then
        oFileDlg.Filter = "Autodesk Inventor Assembly Files (*.iam)|*.iam"
    oFileDlg.InitialDirectory = ThisApplication.FileLocations.Workspace
    oFileDlg.filename = filename(opartdoc.FullFileName)
    oFileDlg.CancelError = True
    On Error Resume Next
    Call oFileDlg.ShowSave
    If err Then
        Exit Sub
    ElseIf oFileDlg.filename <> "" Then
        NewFilePath = oFileDlg.filename
    ThisApplication.SilentOperation = True
    ThisApplication.SilentOperation = False
    Next
    Exit Sub
err:
    On Error GoTo 0
    Resume
End Sub
Function filename_noext(spth As String)
    'Returns filename without extension from full path
    If spth <> "" Then
        filename_noext = Mid(spth, InStrRev(spth, "\") + 1, InStrRev(spth, ".") - InStrRev(spth, "\") - 1)
    Else:
        filename_noext = ""
End Function
Message 8 of 9
Chad.Snyder8B8AB
I am trying to use this macro and its coming up with an error message that says compile error can't find project or library.
I am very very very raw with macros and just trying to get this to work to save me some steps.
Message 9 of 9
Yijiang.Cai
This idea has been implemented within Autodesk Inventor 2024.2. Please review the Inventor 2024.2 What's New article here. For more information regarding how you may leverage the feature, and please review this page. Special thanks to everyone who cast a vote for it.
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
