May I use Visual Studio Express 2015 with Inventor 2017 on Windows 10
Got
MS Windows 10
Inventor 2017
Want to install Visual Studio express for iLogic development.
Found and tried to install Visual Stuido Express 2015 (Desktop)
BUT of cause the installation failed, complaining about a earlier version of C++
Is it worth the trouble to try to get it working or should I go for an earlier
version of "...Express"?
Jef_E
I would recommend the 2015 community edition.. it's also free
https://www.visualstudio.com/downloads/
As the express is NOT listed as download in the Visual Studio Downloads page. Maybe a full uninstall will be of help?
https://msdn.microsoft.com/en-us/library/mt720585.aspx
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
frederic.vandenplas
You should try it uninstall the .NET framework in windows before installing VS.
Inventor 2015 installation had the same problem too with 4.5 .NET Framework
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
