I've recreated this in vba (easier for debugging) and this worked for me
Public Sub setComboItem()
Dim cmdman As CommandManager
Set cmdman = ThisApplication.CommandManager
Dim ctrldefs As ControlDefinitions
Set ctrldefs = cmdman.ControlDefinitions
Dim cmbdef As ComboBoxDefinition
Set cmbdef = ctrldefs.Item("SheetSizeCombobox--> you need to change this to the internal name of the combobox")
If cmbdef Is Nothing Then
Return
Else
'find the sheetsize and set the listindex according to the value
cmbdef.ListIndex = 1
End If
End Sub
I've created a comobobox using this snippet below from another post for my convenience.
' Copy below code to a module
Public oChangeMaterial As clsChangeMaterial
Public Sub CreateComboBox()
' Set a reference to the active document.
' This assumes that a part document is active.
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oCommandMgr As CommandManager
Set oCommandMgr = ThisApplication.CommandManager
' Set a reference to the collection of ControlDefinitions
Dim oControlDefs As ControlDefinitions
Set oControlDefs = oCommandMgr.ControlDefinitions
On Error Resume Next
' Create a combobox definition
Dim oComboBoxDef As ComboBoxDefinition
Set oComboBoxDef = oControlDefs.Item("MaterialsComboBox")
If oComboBoxDef Is Nothing Then
Set oComboBoxDef = oControlDefs.AddComboBoxDefinition("Materials", "MaterialsComboBox", kNonShapeEditCmdType, 125, , "Materials Combo", "Materials")
' Set a reference to the materials collection.
Dim oMaterials As Materials
Set oMaterials = oDoc.Materials
Dim oMaterial As Material
For Each oMaterial In oMaterials
' Add material names to the combo box definition
oComboBoxDef.AddItem (oMaterial.Name)
Next
' Set a reference to the Part Standard toolbar
Dim oPartFeatureToolbar As CommandBar
Set oPartFeatureToolbar = ThisApplication.UserInterfaceManager.CommandBars.Item("PMxPartFeatureCmdBar")
' Add a combo box control to the toolbar
Dim oComboBoxControl As CommandBarControl
Set oComboBoxControl = oPartFeatureToolbar.Controls.AddComboBox(oComboBoxDef,1)
oPartFeatureToolbar.Visible = True
End If
' Clear current selection
oComboBoxDef.ListIndex = 0
Set oChangeMaterial = New clsChangeMaterial
oChangeMaterial.Initialize
End Sub
' The declarations and functions below need to be copied into
' a class module whose name is "clsChangeMaterial". The name
' can be changed but you'll need to change the declaration in
' the calling function "CreateComboBox" to use the new name.
Option Explicit
Private WithEvents oComboBoxDef As ComboBoxDefinition
Public Sub Initialize()
' Set a reference to the "MaterialsComboBox" combo box definition
End Sub
Private Sub oComboBoxDef_OnSelect(ByVal Context As NameValueMap)
If oComboBoxDef.ListIndex = 0 Then
Exit Sub
End If
' Get the selected item
Dim oMaterialName As String
oMaterialName = oComboBoxDef.ListItem(oComboBoxDef.ListIndex)
' Set a reference to the active part document
Dim oPartCompDef As PartComponentDefinition
Set oPartCompDef = oDoc.ComponentDefinition
' Get the selected material
Set oMaterial = oDoc.Materials.Item(oMaterialName)
' Change the part material
oPartCompDef.Material = oMaterial
End Sub
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
