Set Appearance to ComponentOccurence
APvdM
APvdM
In an assembly I try to pick a color from an occurence an apply it to another one.
I got some code from the API help and i am adding some code.
Public Sub SetOccurrenceAppearance()
    Dim asmDoc As AssemblyDocument
    Set asmDoc = ThisApplication.ActiveDocument
    Dim assetLib As AssetLibrary
    Dim libAsset As Asset
    Dim localAsset As Asset
    On Error Resume Next
    Dim occ As ComponentOccurrence
    Set occ = ThisApplication.CommandManager.Pick(kAssemblyOccurrenceFilter, "Selecteer welke kleur overgenomen moet worden.")
    Set localAsset = occ.Appearance
    If Err Then
        On Error GoTo 0
        Set assetLib = ThisApplication.AssetLibraries.Item("Breston")
        Set libAsset = assetLib.AppearanceAssets.Item("Yellow")
        Set localAsset = libAsset.CopyTo(asmDoc)
    End If
    On Error GoTo 0
    Dim occ1 As ComponentOccurrence
    Set occ1 = ThisApplication.CommandManager.Pick(kAssemblyOccurrenceFilter, "Selecteer het te kleuren onderdeel.")
    Set occ1.Appearance = localAsset
End Sub
The last sentence (Set occ1.Appearance = localAsset) gives errors in the inventor VBA.
The same problem appears in Microsoft Visual Studio when i try: oOcc1.Appearance = occColor
Is there anyone who knows what the problem is?
NachoShaw
Looks to me like you are collecting the appeal cell from an assembly part and attempting to apply it to the assembly itself instead of another part.
Wouldn't you need to select another part to copy the appearance to?
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
NachoShaw
Oh hang on, I see the rest of the code now (reading on my phone)....
Have you tried
Set occ1.Appearance = occ.Appearance
Nacho
Nacho
APvdM
Ah, that's a simple solution without the use of extra variabels.. Smiley Tongue
It works nice.. Thanks!
The code I sent yesterday works also, but only when I pick the color of an overrided part. I didn't try that earlier.
Thus picking the color of a parts that's not overrided gives an error.
Maybe because the Appearance (source) type or whatever gives problems?
For sake of completeness: Set occ1.Appearance = occ.Appearance is the right notation. Set before it is not right.
