Addin, VB.NET: Check if form is already open
Patrick1323
Patrick1323
I'm want to check if a form in a inventor instance is already open. Can I use OpenForms to accomplish that? This code is in the StandardAddInServer.vb, so it's not a standalone application.
2016-10-13 07_51_31-IVTBFSchweißteil (Debugging) - Microsoft Visual Studio.png
NachoShaw
Well, if your form called let's say 'MainForm', you could do the following:
Dim f as form = New MainForm
Select Case f.Visible
Case True
MsgBox ("your form is open")
Case False
MsgBox ("your form is not open")
End Select
Always make sure that when you open the form, you open it as New
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
