Select two parallel faces then value drives a parameter
Benjaaamin
Benjaaamin
Hi there folks,
Slowly gaining my iLogic knowledge but curious to know if there was a means (via iLogic) to select two parallel faces within an assembly that then was applied to a user parameter? Basically the same as the measure tool but the result is a forced to update the numerical parameter.
bradeneuropeArthur
Make a sketch and project these workplanes as reference lines, place a sketch dimension and you have your parameter as needed.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
