Select Features and perform Right Mouse Button Click on 'Show Dimensions'
checkcheck_master
Message 1 of 11
checkcheck_master
Already I've got a macro/iLogic rule that turns on all Sketches so you can see and change dimensions.
I like to include the option 'Show Dimensions' for a each feature which give you more dimensions to look at like fillets, chamfers, flanges etc.
When I do that by going through all the features, unfortunately the dimension of the previous feature are made invisible.
When I select the features manually and do a right mouse button/'Show Dimensions' it works perfect, see video.
Is it possible to perform this with iLogic/VBA?
Replies (10)
Message 2 of 11
FINET_Laurent
Is this what you're looking for?
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
Dim oFeature As PartFeature
For Each oFeature In oDoc.ComponentDefinition.Features
	oDoc.SelectSet.Select(oFeature)
Next
ThisApplication.CommandManager.ControlDefinitions.Item("PartShowDimensionsCtxCmd").Execute
Also see this for all commands : https://spiderinnet2.typepad.com/blog/2012/07/inventor-net-find-all-the-control-definitions-1.html
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Message 3 of 11
bradeneuropeArthur
Would this help:
Dim a As Object = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchObjectFilter, "Pick IN BROWSER")
a.DimensionsVisible = True
Pick the sketch in the Browser!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 4 of 11
FINET_Laurent
@bradeneuropeArthurThis doesn't look likes it works for me ? The lines gets fired without exeptions but there is no visible dimensions.
When right clicking on sketches there is no "Show dimensions", only Visible/Invisible. I guess you would need to retrieve dependent features to access "Show dimensions".
Or maybe I broke my Inventor ... :C
Message 5 of 11
checkcheck_master
Wonderful Laurent, it works great, I have implement it in the rule where I show the Sketches. Now al dimensions are available for editing with one click.
Is is also possible to have this working when the part file is in an assembly and in edit mode?
For the sketches this works already this way.
I have de file called as: Dim oDoc As Inventor.Document = ThisApplication.ActiveEditDocument
Message 6 of 11
Ralf_Krieg
Hello
In an assembly you need to create proxy objects of the part features. This snippet should work for both - part and part in assembly.
Dim oAssDoc As AssemblyDocument
Dim oPartDoc As PartDocument
If ThisApplication.ActiveDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
	oAssDoc = ThisApplication.ActiveDocument
	Dim oOcc As ComponentOccurrence = oAssDoc.ComponentDefinition.ActiveOccurrence
	Dim oFeatureProxy As Object
	For Each oFeature In oOcc.Definition.Features
	    oOcc.CreateGeometryProxy(oFeature, oFeatureProxy)
	    oAssDoc.SelectSet.Select(oFeatureProxy)
	Next
ElseIf ThisApplication.ActiveDocumentType = DocumentTypeEnum.kPartDocumentObject Then
	oPartDoc = ThisApplication.ActiveDocument
	For Each oFeature In opartdoc.componentDefinition.Features
    	opartDoc.SelectSet.Select(oFeature)
	Next
R. Krieg
RKW Solutions
www.rkw-solutions.com
Message 7 of 11
checkcheck_master
Thanks Krieg,
I see it works, but I still need to implement it correctly in my existing code. I see that I do certain things in a different way that might be better.
Message 8 of 11
checkcheck_master
Hello Krieg,
I knock again for help.
I manage to make the feature dimensions visible, but I can't get them invisible.
I would also like to expand the browser nodes of the component being edited and see them at the top of the browser. In that case you get an immediate overview of how the component is built without having to click everything open first. Is it possible to make the browser scroll to a certain position through code?
Perhaps unnecessarily:
Throughout this story, I'm using two separate macros, 'Expand Browser' and 'Collapse Browser' which I have under the + and - keys of my numeric keyboard part. Both macros btw use your solution to be able to expand and collapse the browser because of the BUG. 'Collapse Browser' collapses the browser for both a part and an assembly and then opens up several browser nodes such as Model States, Representations-View and -Position and finally Origin. 'Expand Browser' expands everything for an assembly and collapses what I don't want to see, such as Relationships. For a part, among other things, the sketches are unfolded and made visible and now also the dimensions of the features. My wish now is that this also works when the document is edited 'in place'.
Please find both code attached.
' Expand_Browser
' Write to textfile
'Dim strDateAndTime = DateTime.Now.ToString(("yyyy-MM-dd HHmmss"))
'Dim LogFileName As String = "C:\temp\iLogic_Log_" & strDateAndTime & ".txt"
'oWrite = System.IO.File.CreateText(LogFileName)
''oWrite = System.IO.File.CreateText(ThisDoc.PathAndFileName(False) & ".txt")
' Calculate elapsed time
Dim oWatch As New Stopwatch : oWatch.Start()
InventorVb.RunMacro("ApplicationProject", "Collapse_Expand_nav_bug","ExpandAll")
'ThisApplication.CommandManager.ControlDefinitions("AppBrowserCollapseChildrenCmd").Execute
' BUG in IV2022:
'ThisApplication.CommandManager.ControlDefinitions("AppBrowserExpandAllCmd").Execute
'oDoc = ThisDoc.ModelDocument
' Check file type
'If oDoc.DocumentType = kPartDocumentObject Then
	'MessageBox.Show("Wait...")
	'Undo Wrapper
	Dim trans As Transaction = ThisApplication.TransactionManager.StartTransaction(ThisDoc.Document, "Do your thing")
	' Set a reference to the top node of the active browser
	Dim oTopNode As BrowserNode
	oTopNode = oDoc.BrowserPanes.ActivePane.TopNode
	Dim oNode As BrowserNode
	For Each oNode In oTopNode.BrowserNodes
		''oWrite.WriteLine("1st   :" & oNode.FullPath)
		If oNode.FullPath Like "*Solid*" Then
			' If the node is visible and expanded, collapse it.
			'If oNode.Visible = True And oNode.Expanded = True Then
			Try : oNode.Expanded = False
				Catch: End Try
			'End If
		Dim oNode2 As BrowserNode
		For Each oNode2 In oNode.BrowserNodes
			''oWrite.WriteLine(" 2nd  :" & oNode2.FullPath)
			If oNode2.FullPath Like "*Solid*" Then
				'If oNode2.Visible = True And oNode2.Expanded = True Then
				Try : oNode2.Expanded = False
					Catch: End Try
				'End If
			Dim oNode3 As BrowserNode
			For Each oNode3 In oNode2.BrowserNodes
				''oWrite.WriteLine("  3th :" & oNode3.FullPath)
				If oNode3.FullPath Like "*Folded Model:Solid*" Then
					' If the node Is visible And expanded, collapse it.
					If oNode3.Visible = True And oNode3.Expanded = True Then
					Try : oNode3.Expanded = False
						Catch: End Try
'				Dim oNode4 As BrowserNode
'				For Each oNode4 In oNode3.BrowserNodes
'				oWrite.WriteLine("   4th:" & oNode4.FullPath)
'				If oNode4.FullPath Like "*Solid Bodies*" Then
'					' If the node is visible and expanded, collapse it.
'					'If oNode4.Visible = True And oNode4.Expanded = True Then
'					Try: oNode4.Expanded = False
						'Catch: End Try
'					'End If
'				End If
'				Next
			Next
		Next
	Next
' Make Sketches visible
For Each oSketch In oDoc.ComponentDefinition.Sketches
oSketch.Visible = True
Next
For Each oSketch In oDoc.ComponentDefinition.Sketches3d
Next
InventorVb.DocumentUpdate()
'iLogicVb.UpdateWhenDone = True
' Show also the feature dimensions like fillets, flanges etc.
Next
' Deselect Features to hide the dotted line round the model
	oDoc.SelectSet.Remove(oFeature)
Next
'Undo Wrapper
trans.End()
'check file type
'If oDoc.DocumentType = kAssemblyDocumentObject Then
	'MessageBox.Show("Assembly Document Section")
	'Set a reference to the top node of the active browser
		If oNode.FullPath Like "*:Relationships*" Then
			If oNode2.FullPath Like "*:Relationships*" Then
		Next
	Next
'	For Each oSketch In oDoc.ComponentDefinition.Sketches
'	oSketch.Visible = True
'	Next
Try
	Next
'	' Deselect Features to hide the dotted line round the model
'	For Each oFeature In oOcc.Definition.Features
'	    oOcc.CreateGeometryProxy(oFeature, oFeatureProxy)
'	    oAssDoc.SelectSet.Remove(oFeatureProxy)
'	Next
Catch
End Try
' Help
'Collapse All 		- AppBrowserCollapseAllCmd
'Collapse Children 	- AppBrowserCollapseChildrenCmd
'Expand All 		- AppBrowserExpandAllCmd
'           		- AppBrowserExpandAllFoldersCmd
'Expand Children 	- AppBrowserExpandChildrenCmd
'                	- AppBrowserExpandFolderCmd
''Calculate elapsed time.
'oWatch.Stop()
'oWrite.WriteLine(vbNewLine & "Done!" & vbNewLine & ("Elapsed Time: " & oWatch.ElapsedMilliseconds.ToString & " Milliseconds"))
''MsgBox         (vbNewLine & "Done!" & vbNewLine & ("Elapsed Time: " & oWatch.ElapsedMilliseconds.ToString & " Milliseconds"))
'oWrite.Close()
''Dim p As System.Diagnostics.Process = Process.Start(LogFileName)
''ThisDoc.Launch(LogFileName)
''ThisDoc.Launch(ThisDoc.PathAndFileName(False) & ".txt")
' Collapse_Browser
' BUG in IV2022:
InventorVb.RunMacro("ApplicationProject", "Collapse_Expand_nav_bug","CollapseAll")
' Check file type
'If ThisApplication.ActiveDocumentType = DocumentTypeEnum.kPartDocumentObject Then
Logger.Info(oDoc.FullDocumentName)
'Try
	' Check for Normal Part or Sheet Metal Part
	If oDoc.DocumentSubType.DocumentSubTypeID = "{4D29B490-49B2-11D0-93C3-7E0706000000}" Then ' Normal Part (No Sheetmetal)
		Dim oNode1 As BrowserNode
		For Each oNode1 In oTopNode.BrowserNodes
			Try : If oNode1.FullPath Like "*Model States*" Then oNode1.Expanded = True
				Catch: End Try
			'If oNode1.FullPath Like "*Folded Model*" Then oNode1.Expanded = True
			Try :If oNode1.FullPath Like "*Solid Bodies*" Then oNode1.Expanded = True
				Catch: End Try
			Try :If oNode1.FullPath Like "*View*" Then oNode1.Expanded = True
				Catch: End Try
			Try :If oNode1.FullPath Like "*Origin*" Then oNode1.Expanded = True
				Catch: End Try
'			Dim oNode2 As BrowserNode
'			For Each oNode2 In oNode1.BrowserNodes
'				If oNode2.FullPath Like "*Model States*" Then oNode2.Expanded = True
'				If oNode2.FullPath Like "*Folded Model*" Then oNode2.Expanded = True
'				If oNode2.FullPath Like "*Solid Bodies*" Then oNode2.Expanded = True
'				If oNode2.FullPath Like "*View*" Then oNode2.Expanded = True
'				If oNode2.FullPath Like "*Origin*" Then oNode2.Expanded = True
'				Dim oNode3 As BrowserNode
'				For Each oNode3 In oNode2.BrowserNodes
'					If oNode3.FullPath Like "*Model States*" Then oNode3.Expanded = True
'					If oNode3.FullPath Like "*Folded Model*" Then oNode3.Expanded = True
'					If oNode3.FullPath Like "*Solid Bodies*" Then oNode3.Expanded = True
'					If oNode3.FullPath Like "*View*" Then oNode3.Expanded = True
'					If oNode3.FullPath Like "*Origin*" Then oNode3.Expanded = True
'				Next
'			Next
		Next
	If oDoc.DocumentSubType.DocumentSubTypeID = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then ' Sheetmetal Part
				Catch:MessageBox.Show("Error when expand Model States") : End Try
			Try : If oNode1.FullPath Like "*Folded Model*" Then oNode1.Expanded = True
				Catch:MessageBox.Show("Error when expand Folded Model") : End Try
'			Try :If oNode1.FullPath Like "Solid Bodies*" Then oNode1.Expanded = True
'				Catch: End Try
'			Try :If oNode1.FullPath Like "*View*" Then oNode1.Expanded = True
'				Catch: End Try
'			Try :If oNode1.FullPath Like "*Origin*" Then oNode1.Expanded = True
'				Catch: End Try
'				Try :If oNode2.FullPath Like "*Model States*" Then oNode2.Expanded = True
'					Catch: End Try
'				Try :If oNode2.FullPath Like "*Folded Model*" Then oNode2.Expanded = True
'					Catch: End Try
				Try :If oNode2.FullPath Like "*Solid Bodies*" Then oNode2.Expanded = True
					Catch : 'MessageBox.Show("Error when expand Solid Bodies")
						End Try
				Try :If oNode2.FullPath Like "*Folded Model:View*" Then oNode2.Expanded = True
					Catch : 'MessageBox.Show("Error when expand Folded Model:View")
						End Try
				Try :If oNode2.FullPath Like "*Origin*" Then oNode2.Expanded = True
					Catch : 'MessageBox.Show("Error when expand Origin")
						End Try
'				Next
			Next
		Next
'Catch
'End Try
	' Turn on Sketches
	oSketch.Visible = False
	Next
	For Each oSketch In oDoc.ComponentDefinition.Sketches3D
	Next
	' Rebuild
	Try
	Catch
		MessageBox.Show("File Is Not Checked Out?")
	End Try
'' Deselect Features to hide the dotted line round the model
'For Each oFeature In oDoc.ComponentDefinition.Features
'	oDoc.SelectSet.Remove(oFeature)
'Next
Else If oDoc.DocumentType = kAssemblyDocumentObject Then
'ElseIf ThisApplication.ActiveDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
	' Undo Wrapper
	Dim trans As Transaction = ThisApplication.TransactionManager.StartTransaction(ThisDoc.Document, "Do your thing...")
		' Eerder hebben we alles INgeklapt, nu willen we een aantal folders UITgeklapt hebben
			If oNode1.FullPath Like "*:Model States*" Or _
			   oNode1.FullPath Like "*:Representations*" Or _
			   oNode1.FullPath Like "*:View*" Or _
			   oNode1.FullPath Like "*Position*" Or _
			   oNode1.FullPath Like "*:Origin*" Or _
			   oNode1.FullPath Like "*xxWelds*" Or _
			   oNode1.FullPath Like "*xxBeads*" Or _
			   oNode1.FullPath Like "*Sheet" Then
				If oNode1.Visible = True And oNode1.Expanded = False Then
				If oNode2.FullPath Like "*Position*" Or _
				   oNode2.FullPath Like "*View*" Or _
				   oNode2.FullPath Like "*xxWelds*" Or _
				   oNode2.FullPath Like "*xxBeads*" Or _
				   oNode2.FullPath Like "*Sheet" Then
					If oNode2.Visible = True And oNode2.Expanded = False Then
			Next
		Next
	' Undo Wrapper
	trans.End()
'	oAssDoc = ThisApplication.ActiveDocument
'	Dim oOcc As ComponentOccurrence = oAssDoc.ComponentDefinition.ActiveOccurrence
'	Dim oFeatureProxy As Object
'	Next
Try
Catch
End Try
'MessageBox.Show("Done")
Message 9 of 11
checkcheck_master
Hello Krieg,
I wrote before:
But I certainly didn't mean that.
It should have been 'they could be better' 🙂
Message 10 of 11
Ralf_Krieg
Hello
" but I can't get them invisible."
I  could not found a direct way, but a workaround that seems to do the job.
Dim oSelectSet As SelectSet
	oOcc = oAssDoc.ComponentDefinition.ActiveOccurrence
	oSelectSet=oAssDoc.selectset
	oSelectSet.Clear
    oOcc.CreateGeometryProxy(oOcc.Definition.Features(1), oFeatureProxy)
	oSelectSet.Clear
	oSelectSet=oPartDoc.selectset
	oSelectSet.Clear
    opartDoc.SelectSet.Select(opartdoc.componentdefinition.features(1))
	oSelectSet.Clear
" Is it possible to make the browser scroll to a certain position through code?"
As far as I know there's no way. But you can use the Command below while the Occurrence or Feature you want to be on top is selected.
ThisApplication.CommandManager.ControlDefinitions("AppFindInBrowserCtxCmd").Execute
Your third question, to make the whole script running in part edit mode, takes more time to review. Don't know if I can do that within next days.
R. Krieg
RKW Solutions
Message 11 of 11
checkcheck_master
Thanks again Krieg, I'm gonna study your answer and try to understand and implement as far as possible.
