Select ClientGraphics objects without ClientID
cambox
cambox
Hi API-Experts!
I use an Inventor application (Add-In) from a vendor that inserted ClientGraphics objects
to show the graphics and store some information. This information I would like to use in
my application. Is there a way to select this objects by a API method and get the information
without the ClientID of this application?
Does anyone have a suggestion?
adam.nagy
Autodesk Support
Autodesk Support
If you have the Add-In installed and running, then you can find it in the ApplicationAddIns collection. And each ApplicationAddIn has a ClientId property.
Cheers,
Adam Nagy
Autodesk Platform Services
cambox
Hi Adam, That's exactly what I am looking for. So that I can continue to work... Many thanks for your response! Regards
