SectionTwistSweep C# API
Hello.
I am trying to make sweep function with section twisted sweep. (like Helical Gear)
I made below codes but got runtime error at last line.
(Commented lines are my challenges but not worked)
I attach twisted sweep feature result by manual operation.
Sketch3D oSketch3D = oPartDoc.ComponentDefinition.Sketches3D.Add();
Point stPoint = oTransGeom.CreatePoint(0, 0, 0);
Point endPoint = oTransGeom.CreatePoint(0, 0, 10);
SketchLine3D oLine = oSketch3D.SketchLines3D.AddByTwoPoints(stPoint, endPoint);
Path oPath = oCompDef.Features.CreatePath(oLine);
PlanarSketch oSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes[3]);
SketchEntitiesEnumerator oRectangle = oSketch.SketchLines.AddAsTwoPointRectangle(oTransGeom.CreatePoint2d(1, 1), oTransGeom.CreatePoint2d(4, 3));
Profile oProfile = oSketch.Profiles.AddForSolid();
SweepDefinition sweepDef = oCompDef.Features.SweepFeatures.CreateSweepDefinition(SweepTypeEnum.kPathAndSectionTwistSweepType, oProfile, oPath, PartFeatureOperationEnum.kJoinOperation);
sweepDef.TwistAngle = Math.PI / 2.0;
//ObjectCollection oCollectionPt = ThisApplication.TransientObjects.CreateObjectCollection();
//oCollectionPt.Add(stPoint);
//ObjectCollection oCollectionVec = ThisApplication.TransientObjects.CreateObjectCollection();
//UnitVector dirVec = oTransGeom.CreateUnitVector(0, 0, 1);
//oCollectionVec.Add(dirVec);
//sweepDef.SetSectionTwists(oCollectionPt, oCollectionVec);
oCompDef.Features.SweepFeatures.Add(sweepDef);
Is there anybody have solution?
So I found a couple things.
I changed PartFeatureOperationEnum.kJoinOperation to PartFeatureOperationEnum.kNewBodyOperation, because I assume you are trying to make new solid with this.
Also changed SweepTypeEnum.kPathAndSectionTwistSweepType to SweepTypeEnum.kPathSweepType, because in the API documents it says sweepDef.TwistAngle is only applicable when using kPathSweepType.
I completely removed where you were creating object collections to add to sweepDef.SetSectionTwists(oCollectionPt, oCollectionVec) because the API docs say sweepDef.SetSectionTwists is only applicable when using kPathAndSectionTwistSweepType.
 I used a website to convert your code to VB.NET and back to C# so let me know if there are problems
PartDocument oPartDoc = ThisDoc.Document;
    ComponentDefinition oCompDef = oPartDoc.ComponentDefinition;
    TransientGeometry oTransGeom = ThisApplication.TransientGeometry;
    PlanarSketch oSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes(3));
    SweepDefinition sweepDef = oCompDef.Features.SweepFeatures.CreateSweepDefinition(SweepTypeEnum.kPathSweepType, oProfile, oPath, PartFeatureOperationEnum.kNewBodyOperation);
