The error : Exception from HRESULT 0x80070057
Hi all,
Thanks to all your help, I developed a windows application that creates simple drawings automatically. Now I let my other colleagues to test my first application but the problem is that it is working very well on my PC but on my colleague's PC, it gives me an error message below saying "Exception from HRESULT 0x80070057", "Parameter is incorrect" etc..
I already double checked about following points;
  1. Inventor is active.
  2. Inventor version is 2021 (that is same version as I use).
  3. Template file is stored on the internal server, not on my PC.
  4. Assigned file name is unique (new), not same to existing file.
Sorry for my spaghetti code but here it is.
Imports Inventor
Public Class Form1
    Dim internalDiameter As Double
    Dim externalDiameter As Double
    Dim height As Double
    Dim radius1 As Double
    Dim radius2 As Double
    Dim endless As Boolean
    Dim split As Boolean
    Dim splitType As String
    Dim drawingNumber As String
    Dim partDoc As Inventor.PartDocument
    Dim param As Inventor.Parameter
    Dim invApp As Inventor.Application
    '##### Endless/Split Boolean'
    Public Sub radiobutton_endless_Click(sender As Object, e As EventArgs) Handles radiobutton_endless.Click
        If radiobutton_endless.Checked = True Then
            endless = True
            splitType = "Endless"
    End Sub
    Public Sub radiobutton_split_Click(sender As Object, e As EventArgs) Handles radiobutton_split.Click
        If radiobutton_split.Checked = True Then
            split = True
            splitType = "Double Splits"
    End Sub
    Public Sub button_ok_Click(sender As Object, e As EventArgs) Handles button_ok.Click
        '##### Get the values from textbox and store as variable (Double)'
        internalDiameter = textbox_internalDiameter.Text
        externalDiameter = textbox_externalDiameter.Text
        height = textbox_height.Text
        drawingNumber = textbox_drawingNumber.Text
        Dim fascia As Double = (externalDiameter - internalDiameter) * 0.5
        Dim medio As Double = (externalDiameter + internalDiameter) * 0.5
        ' ##### Verifying the values
        If internalDiameter > externalDiameter Then
            MessageBox.Show("Internal Diameter must be smaller than external diameter!", "Wrong Dimension", MessageBoxButtons.OK, MessageBoxIcon.Stop)
            Me.Close()
        If internalDiameter + 7 >= externalDiameter Then
            MessageBox.Show("Cross section is too small!", "Wrong Dimension", MessageBoxButtons.OK, MessageBoxIcon.Stop)
            Me.Close()
        If height > 50 Then
            MessageBox.Show("Isn't the height too high?" & vbCrLf & "Lower the height and insert a backup ring.", "Wrong Dimension", MessageBoxButtons.OK, MessageBoxIcon.Warning)
            Me.Close()
        If height < fascia * 0.7 Then
            Dim fasciaMinimum As Double = (fascia * 0.7) + 0.05
            MessageBox.Show("The height is too low. Make it higher than " & Math.Round([fasciaMinimum], 1, MidpointRounding.AwayFromZero) & " mm.", "Wrong dimension", MessageBoxButtons.OK, MessageBoxIcon.Stop)
            Me.Close()
        If internalDiameter > 2100 Or externalDiameter > 2100 Then
            MessageBox.Show("Isn't the diameter too big? Contact ufficio tecnico.", "Troppo grande", MessageBoxButtons.OK, MessageBoxIcon.Warning)
            Me.Close()
        '##### Get the Inventor Application object
        invApp = GetObject(, "Inventor.Application")
        '##### Open the part.'
        invApp.Documents.Open("\\dataserver2019\Tecnici\CARCO\EngineeringTEAM\AUTOMATIC_CREATOR\automated-drawing-female.ring\automated-drawing-female.ring\female_ring.ipt")
        '##### Get the active document. This assums it's a part document.
        partDoc = invApp.ActiveDocument
        '##### Get the Parameters collection.
        Dim params As Inventor.Parameters
        params = partDoc.ComponentDefinition.Parameters
        '##### Get the parameter named "fasica_parameter"'
        Dim oFasciaParam As Inventor.Parameter
        oFasciaParam = params.Item("fascia_parameter")
        '##### Get the parameter named "height_parameter"'
        Dim oHeightParam As Inventor.Parameter
        oHeightParam = params.Item("height_parameter")
        '##### Get the parameter named "externalDiameter_parameter"'
        Dim oExternalDiameterParam As Inventor.Parameter
        oExternalDiameterParam = params.Item("externalDiameter_parameter")
        ' Get the parameter named "radius1_parameter"
        Dim oRadius1Param As Inventor.Parameter
        oRadius1Param = params.Item("radius1_parameter")
        ' Get the parameter named "radius2_parameter"
        Dim oRadius2Param As Inventor.Parameter
        oRadius2Param = params.Item("radius2_parameter")
        '##### Calculation Fascia
        If textbox_externalDiameter.Text < 300 Then
            fascia = fascia - 0.4
        ElseIf textbox_externalDiameter.Text >= 300 And textbox_externalDiameter.Text < 900 Then
            fascia = fascia - 0.6
        Else
            fascia = fascia - 0.8
        ' Set the range of "Radius1" & "Radius2"
        If fascia <= 5 Then
            radius1 = 1
            radius2 = 0.5
        ElseIf fascia > 5 And fascia <= 7 Then
            radius1 = 1
            radius2 = 1
        ElseIf fascia > 7 And fascia <= 9 Then
            radius1 = 1
            radius2 = 1.5
        ElseIf fascia > 9 And fascia <= 10.25 Then
            radius1 = 1
            radius2 = 2
        ElseIf fascia > 10.25 And fascia <= 13.5 Then
            radius1 = 1.5
            radius2 = 2
        ElseIf fascia > 13.5 And fascia <= 17.75 Then
            radius1 = 1.5
            radius2 = 3
        ElseIf fascia > 17.75 And fascia <= 22.2 Then
            radius1 = 2
            radius2 = 3
        ElseIf fascia > 22.2 And fascia <= 22.9 Then
            radius1 = 2.5
            radius2 = 3
        ElseIf fascia > 22.9 And fascia <= 28.5 Then
            radius1 = 2.5
            radius2 = 3.5
        Else                                              ' fascia >28.5
            radius1 = 2.5
            radius2 = 5
        '##### Calculation External diameter
        externalDiameter = medio + fascia
        '##### Assign extra 1mm on diameter in case of double split.'
        If split = True Then
            externalDiameter = externalDiameter + 1
        ' ##### Tolerance setting
        ' Fascia
        If fascia < 15 Then
            Call oFasciaParam.Tolerance.SetToSymmetric("0.1 mm")
        Else
            Call oFasciaParam.Tolerance.SetToSymmetric("0.15 mm")
        'Height
        If height < 15 Then
            Call oHeightParam.Tolerance.SetToSymmetric("0.1 mm")
        Else
            Call oHeightParam.Tolerance.SetToSymmetric("0.15 mm")
        ' TOLERANCE External Diameter
        ' DOUBLE SPLIT
        If split = True And externalDiameter < 1100 Then
            Call oExternalDiameterParam.Tolerance.SetToDeviation("1.0 mm", "-0.0 mm")
        If split = True And externalDiameter >= 1100 Then
            Dim splitToleranceExternalDiameter As Double = externalDiameter * 0.0001
            Call oExternalDiameterParam.Tolerance.SetToDeviation(Math.Round([splitToleranceExternalDiameter], 2), "-0,0 mm")  ' standard unit is cm, thus apply extra 0.1
        ' ENDLESS 2 CASES : CROSS SECTION 15.0 mm
        Dim PositiveToleranceSmallerThan15 As Double
        Dim NegativeToleranceSmallerThan15 As Double
        Dim PositiveToleranceBiggerThan15 As Double
        Dim NegativeToleranceBiggerThan15 As Double
        If endless = True And fascia < 15 Then
            PositiveToleranceSmallerThan15 = textbox_externalDiameter.Text - medio - fascia - 0.1
            NegativeToleranceSmallerThan15 = (medio + fascia) - fascia - fascia - textbox_internalDiameter.Text - 0.2 - 0.1
            Call oExternalDiameterParam.Tolerance.SetToDeviation(PositiveToleranceSmallerThan15 * 0.1, NegativeToleranceSmallerThan15 * -0.1)
        If endless = True And fascia >= 15 Then
            PositiveToleranceBiggerThan15 = textbox_externalDiameter.Text - medio - fascia - 0.1
            NegativeToleranceBiggerThan15 = (medio + fascia) - fascia - fascia - textbox_internalDiameter.Text - 0.3 - 0.1
            Call oExternalDiameterParam.Tolerance.SetToDeviation(PositiveToleranceBiggerThan15 * 0.1, NegativeToleranceBiggerThan15 * -0.1)
        ' Final tolerance for split
        Dim finalTolerancePositive As Double
        Dim finalToleranceNegative As Double
        If fascia < 15 Then
            finalTolerancePositive = textbox_externalDiameter.Text - medio - fascia - 0.1
            finalToleranceNegative = ((medio + fascia) - fascia - fascia - textbox_internalDiameter.Text - 0.2 - 0.1) * -1
        If fascia >= 15 Then
            finalToleranceNegative = ((medio + fascia) - fascia - fascia - textbox_internalDiameter.Text - 0.3 - 0.1) * -1
        finalTolerancePositive = Math.Round([finalTolerancePositive], 2)
        finalToleranceNegative = Math.Round([finalToleranceNegative], 2)
        '##### Change the equation of the parameter.'
        oFasciaParam.Expression = fascia
        oHeightParam.Expression = height
        oExternalDiameterParam.Expression = externalDiameter
        oRadius1Param.Expression = radius1
        oRadius2Param.Expression = radius2
        '##### ///Controlling iProperties part'
        '##### Get the "Design Tracking Properties" property set.'
        Dim designTrackPropSet As Inventor.PropertySet
        designTrackPropSet = partDoc.PropertySets.Item("Design Tracking Properties")
        '##### Assign "Drawing N°".'
        '##### Get the "Description" property from the property set.'
        Dim descProp As Inventor.Property
        descProp = designTrackPropSet.Item("Description")
        '##### Set the value of the property using the current value of the textbox.'
        descProp.Value = textbox_object.Text
        ' ##### Assign "Material"
        ' ##### Get the "Material" property from the property set.
        Dim materialType As Inventor.Property
        materialType = designTrackPropSet.Item("Material")
        ' ##### Set the value of the property using the value from input form
        materialType.Value = comboBox_materialType.Text
        '##### Assign "Description (Endless/Double splits)".'
        '##### Get the "Project" property from the property set.'
        Dim splitProp As Inventor.Property
        splitProp = designTrackPropSet.Item("Project")
        If endless = True Then
            splitProp.Value = "Female ring Endless"
            splitProp.Value = "Female ring double splits"
        '##### Assign "Housing dimension".'
        '##### Get the "Inventor Summary Information" property set.'
        Dim inventorSummaryInfoPropSet As Inventor.PropertySet
        inventorSummaryInfoPropSet = partDoc.PropertySets.Item("Inventor Summary Information")
        '##### Get the "Subject" property from the property set.'
        Dim housingProp As Inventor.Property
        housingProp = inventorSummaryInfoPropSet.Item("Subject")
        housingProp.Value = internalDiameter.ToString() + "/" + textbox_externalDiameter.Text.ToString() + " * " + textbox_housingHeight.Text.ToString()
        ' Drawing for a third party
        'If checkBox_thirdParty.Checked = True Then
        'End If
        '##### Update the document.'
        invApp.ActiveDocument.Update()
        ' ##### Add revision N° in each exported file name (Except Rev.0)
        Dim revision As String
        If comboBox_revision.Text = "0" Or comboBox_revision.Text = "" Then
            revision = ""
        Else
            revision = "_rev." + comboBox_revision.Text
        '##### Save the part-document with the assigned name (drawingNumber).'
        invApp.ActiveDocument.SaveAs("\\dataserver2019\Tecnici\CARCO\DISEGNI\TORNITURA+MODIFICHE\" + drawingNumber + revision + ".ipt", False)
        '##### Replace the reference .ipt file on the drawing.'
        Dim oDoc As Inventor.DrawingDocument
        oDoc = invApp.Documents.Open("\\dataserver2019\Tecnici\CARCO\EngineeringTEAM\AUTOMATIC_CREATOR\automated-drawing-female.ring\automated-drawing-female.ring\female_ring.idw")
        oDoc.File.ReferencedFileDescriptors(1).ReplaceReference("\\dataserver2019\Tecnici\CARCO\DISEGNI\TORNITURA+MODIFICHE\" + drawingNumber + revision + ".ipt")
        '##### Scale the drawing views according to the external diameter.'
        ' ##### View A'
        Dim oViewA As DrawingView
        oViewA = oDoc.ActiveSheet.DrawingViews.Item(1)
        If textbox_externalDiameter.Text < 100 Then
            oViewA.[Scale] = 0.8
        ElseIf textbox_externalDiameter.Text >= 100 And textbox_externalDiameter.Text < 150 Then
            oViewA.[Scale] = 0.7
        ElseIf textbox_externalDiameter.Text >= 150 And textbox_externalDiameter.Text < 200 Then
            oViewA.[Scale] = 0.65
        ElseIf textbox_externalDiameter.Text >= 200 And textbox_externalDiameter.Text < 250 Then
        ElseIf textbox_externalDiameter.Text >= 250 And textbox_externalDiameter.Text < 300 Then
            oViewA.[Scale] = 0.55
        ElseIf textbox_externalDiameter.Text >= 300 And textbox_externalDiameter.Text < 350 Then
            oViewA.[Scale] = 0.45
        ElseIf textbox_externalDiameter.Text >= 350 And textbox_externalDiameter.Text < 400 Then
        ElseIf textbox_externalDiameter.Text >= 400 And textbox_externalDiameter.Text < 450 Then
            oViewA.[Scale] = 0.35
        ElseIf textbox_externalDiameter.Text >= 450 And textbox_externalDiameter.Text < 500 Then
        ElseIf textbox_externalDiameter.Text >= 500 And textbox_externalDiameter.Text < 550 Then
            oViewA.[Scale] = 0.25
        ElseIf textbox_externalDiameter.Text >= 550 And textbox_externalDiameter.Text < 600 Then
        ElseIf textbox_externalDiameter.Text >= 600 And textbox_externalDiameter.Text < 650 Then
        ElseIf textbox_externalDiameter.Text >= 650 And textbox_externalDiameter.Text < 700 Then
        ElseIf textbox_externalDiameter.Text >= 700 And textbox_externalDiameter.Text < 750 Then
        ElseIf textbox_externalDiameter.Text >= 750 And textbox_externalDiameter.Text < 800 Then
        ElseIf textbox_externalDiameter.Text >= 800 And textbox_externalDiameter.Text < 850 Then
            oViewA.[Scale] = 0.15
        ElseIf textbox_externalDiameter.Text >= 850 And textbox_externalDiameter.Text < 900 Then
        ElseIf textbox_externalDiameter.Text >= 900 And textbox_externalDiameter.Text < 950 Then
        ElseIf textbox_externalDiameter.Text >= 950 And textbox_externalDiameter.Text < 1000 Then
        ElseIf textbox_externalDiameter.Text >= 1000 And textbox_externalDiameter.Text < 1050 Then
        ElseIf textbox_externalDiameter.Text >= 1050 And textbox_externalDiameter.Text < 1100 Then
        ElseIf textbox_externalDiameter.Text >= 1100 And textbox_externalDiameter.Text < 1150 Then
        ElseIf textbox_externalDiameter.Text >= 1150 And textbox_externalDiameter.Text < 1200 Then
        ElseIf textbox_externalDiameter.Text >= 1200 And textbox_externalDiameter.Text < 1250 Then
        ElseIf textbox_externalDiameter.Text >= 1250 And textbox_externalDiameter.Text < 1300 Then
        Else
            oViewA.[Scale] = 0.05
        ' ##### Detail view "B".'
        Dim oViewB As DetailDrawingView
        For Each oSheet As Sheet In oDoc.Sheets
            For Each oView As DrawingView In oSheet.DrawingViews
                If oView.ViewType = DrawingViewTypeEnum.kDetailDrawingViewType Then
                    oViewB = oView
            Next
        Next
        'Set the scale of Detail View B depending on the size
        'Scale the detail drawing view according to the height.
        If textbox_height.Text < 5 Then
            oViewB.[Scale] = 3
        ElseIf textbox_height.Text >= 5 And textbox_height.Text < 20 Then
            oViewB.[Scale] = 2.5
        ElseIf textbox_height.Text >= 20 And textbox_height.Text < 35 Then
            oViewB.[Scale] = 2
        Else
            oViewB.[Scale] = 1.5
        ' ##### 3D view "View3D".'
        Dim oView3D As DrawingView
                If oView.ViewType = DrawingViewTypeEnum.kProjectedDrawingViewType Then
                    oView3D = oView
            Next
        Next
        'Set the scale of 3D view depending on the size
            oView3D.[Scale] = 0.4
        ElseIf textbox_externalDiameter.Text >= 100 And textbox_externalDiameter.Text < 200 Then
            oView3D.[Scale] = 0.2
        ElseIf textbox_externalDiameter.Text >= 200 And textbox_externalDiameter.Text < 400 Then
            oView3D.[Scale] = 0.15
        ElseIf textbox_externalDiameter.Text >= 400 And textbox_externalDiameter.Text < 700 Then
        ElseIf textbox_externalDiameter.Text >= 700 And textbox_externalDiameter.Text < 1000 Then
            oView3D.[Scale] = 0.05
        ElseIf textbox_externalDiameter.Text >= 1000 And textbox_externalDiameter.Text < 1200 Then
            oView3D.[Scale] = 0.04
        Else
            oView3D.[Scale] = 0.03
        ' ##### Update the revision table
        Dim oRevisionTable As RevisionTable = oDoc.ActiveSheet.RevisionTables.Item(1)
        Dim oRow As RevisionTableRow = oRevisionTable.RevisionTableRows.Item(1)
        Dim oCell1 As RevisionTableCell = oRow.Item(1)
        Dim oCell2 As RevisionTableCell = oRow.Item(2)
        Dim oCell3 As RevisionTableCell = oRow.Item(3)
        Dim oCell4 As RevisionTableCell = oRow.Item(4)
        Dim oCell5 As RevisionTableCell = oRow.Item(5)
        Dim oggi As Date = Date.Today   ' Date
            oCell1.Text = "0"
        Else
            oCell1.Text = comboBox_revision.Text    ' Revision N°
        If oCell1.Text = "0" Or oCell1.Text = "" Then                    ' Description (If Revision N° is "0", assign "Drawing Issue"
            oCell2.Text = "Drawing Issue"
        Else
            oCell2.Text = textbox_description.Text
        oCell3.Text = "Automated"               ' Drawn
        oCell4.Text = textbox_signature.Text    ' Approved
        oCell5.Text = oggi                      ' Date (dd/mm/yyyy)
        '##### Save the drawing-document with the assigned name (drawingNumber).'
        invApp.ActiveDocument.SaveAs("\\dataserver2019\Tecnici\CARCO\DISEGNI\TORNITURA+MODIFICHE\" + drawingNumber + revision + ".idw", False)
        ' ##### Export to PDF.'
        ' Get the active docuement.
        oDoc = invApp.ActiveDocument
        ' Save a copy as a PDF file.
        Call oDoc.SaveAs("\\dataserver2019\Tecnici\CARCO\DISEGNI\TORNITURA+MODIFICHE\" + drawingNumber + revision + ".pdf", True)
        ' Save a copy as a jpeg file.
        'Call oDoc.SaveAs("\\dataserver2019\Tecnici\CARCO\DISEGNI\TORNITURA+MODIFICHE\" + drawingNumber + ".jpg", True)
            MessageBox.Show("Automated drawing is generated. Please double check!", "Taaaaaac! :D", MessageBoxButtons.OK, MessageBoxIcon.None)
            MessageBox.Show("Automated drawing is generated. Please double check!" & vbCrLf & vbCrLf & "This backup ring is split. Final external diameter value is " & externalDiameter - 1 & " mm" & vbCrLf & "(Tol. +" & finalTolerancePositive & "/" & finalToleranceNegative & " mm)", "Taaaaaac! :D", MessageBoxButtons.OK, MessageBoxIcon.None)
        Me.Close()
    End Sub
End Class
Check to see if the user can read and write to this location from their PC, this drive may not have the same mapping for them.
Thank you @Anonymous
As you suggested, the application had a problem to access template .ipt and .idw files. I changed the code of file location part and it works perfectly now. I wish the error message could give me a clue what is the problem.
