Search internal rules in multiple parts and replace text
Good Day,
I have a main assembly with sub-assemblies and those sub-assemblies have internal rules.
Each one of those sub-assemblies have an identical rule to each other.
From my main assembly is there a way to go to each sub assembly,  open the rule,  search for text and replace it with other text?
This is so that I do not need to go to each rule and modify them manually.
There are many.
JhoelForshav
Hi @Anonymous
See example below. This code will find the rule named RuleName in all subassemblies and replace the text "Hello" with "Good bye" in them 🙂
Dim oAsm As AssemblyDocument = ThisDoc.Document
For Each oRefDoc As Document In oAsm.ReferencedDocuments
	If oRefDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject
		Try
		Dim oRule As iLogicRule = iLogicVb.Automation.GetRule(oRefDoc, "RuleName")
		oRule.Text = oRule.Text.Replace("Hello", "Good bye")
		Catch
		End Try
	End If
Next
Your solutions never disappoint.
Thank you.
One more question if you don't mind.
Is there a way to create a rule in all of the sub-assemblies and paste data into it and save the rule?
JhoelForshav
@Anonymous
Here's an example on creating rules:
		Try
			'Create the rule with empty text first, otherwise iLogic will run the rule immediatley after creation
			Dim oRule As iLogicRule = iLogicVb.Automation.AddRule(oRefDoc, "NewRule", "")
			'Set the rule text as a string. use doubble " ("") for " in the srring and vbCrlf for linebreak
			oRule.Text = "MsgBox(""messagebox on line 1"")" & vbCrLf & _
			"MsgBox(""messagebox on line 2"")"
		Catch
		End Try
	End If
Next
Worked 100%
Always to the point and effective solutions.
Thank you.
