how to calculate with an variable in mm
Darkforce_the_ilogic_guy
Advisor Advisor
I have an ilogic that I trying to take an price *number of profil * length of profil
when I just calculate price *number of profil it work fine , but my code stop working as soon as I try  to add the length of profil.. the code fail.  I have no idear of why...
Public Sub Main()
Dim NameList As New ArrayList()
Dim IsRHS As Boolean = False
Dim wrongDisplayname As String
Dim Tocopypast As String
Dim oAsmDoc As AssemblyDocument
Dim Antal
oAsmDoc = ThisApplication.ActiveDocument
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
NameList.Add("3116030034")
NameList.Add("3116040043")
NameList.Add("3116040044")
NameList.Add("3116030053")
NameList.Add("3116030054")
NameList.Add("3116050053")
NameList.Add("3116050054")
NameList.Add("3116050055")
NameList.Add("3116050056")
NameList.Add("3116050058")
NameList.Add("3116040063")
NameList.Add("3116040064")
NameList.Add("3116030064")
NameList.Add("3116060064")
NameList.Add("3116060065")
NameList.Add("3116060066")
NameList.Add("3116040084")
NameList.Add("3116040085")
NameList.Add("3116040086")
NameList.Add("3116050084")
NameList.Add("3116050085")
NameList.Add("3116080065")
NameList.Add("3116080083")
NameList.Add("3116080084")
NameList.Add("3116080085")
NameList.Add("3116080086")
NameList.Add("3116080088")
NameList.Add("3116090098")
NameList.Add("3116050103")
NameList.Add("3116050104")
NameList.Add("3116050106")
NameList.Add("3116050108")
NameList.Add("3116060103")
NameList.Add("3116060106")
NameList.Add("3116080104")
NameList.Add("3116080106")
NameList.Add("3116100104")
NameList.Add("3116100105")
NameList.Add("3116100106")
NameList.Add("3116100108")
NameList.Add("3116100109")
NameList.Add("3116060124")
NameList.Add("3116060125")
NameList.Add("3116060126")
NameList.Add("3116060128")
NameList.Add("3116060129")
NameList.Add("3116080125")
NameList.Add("3116080126")
NameList.Add("3116120125")
NameList.Add("3116120128")
NameList.Add("3116120130")
NameList.Add("3116140150")
NameList.Add("3116075156")
NameList.Add("3116100155")
NameList.Add("3116100156")
NameList.Add("3116100158")
NameList.Add("3116100159")
NameList.Add("3116080164")
NameList.Add("3116080165")
NameList.Add("3116080166")
NameList.Add("3116080168")
NameList.Add("3116080169")
NameList.Add("3116160168")
NameList.Add("3116180180")
NameList.Add("3116100205")
NameList.Add("3116100206")
NameList.Add("3116100208")
NameList.Add("3116100210")
NameList.Add("3116120206")
NameList.Add("3116200206")
NameList.Add("3116150256")
NameList.Add("3116100308")
NameList.Add("3116100310")
NameList.Add("3116200410")
NameList.Add("3116400410")
For Each oRefDoc In oRefDocs
	For Each rawmaterial In NameList
Try
If iProperties.Value(oRefDoc.DisplayName, "Custom", "Raw Material") = rawmaterial Then
IsRHS = True
assemblyDoc = oAsmDoc
assemblyDef = assemblyDoc.ComponentDefinition
Antal = assemblyDef.Occurrences.AllReferencedOccurrences(oRefDoc)
Length = iProperties.Value(oRefDoc.DisplayName, "Custom", "G_L")
MsgBox(iProperties.Value(oRefDoc.DisplayName, "Custom", "G_L"))
'debug("Length " & Length.ToString )
price =  Antal.Count * 42 '* Length
debug(iProperties.Value(oRefDoc.DisplayName, "Project", "Part Number") & " " & "number of unit " & Antal.Count.ToString & " Money Save by change to RHP " & price & " kr")
Catch
IsRHS = False
End Try
Next
If IsRHS = True Then
	If  iProperties.Value(oRefDoc.DisplayName, "Custom", "Raw Material") <>  "" Then
	debug(iProperties.Value(oRefDoc.DisplayName,"Project", "Part Number"))
wrongDisplayname = wrongDisplayname & vbLf & vbLf & "Partnumber " & iProperties.Value(oRefDoc.DisplayName, "Project", "Part Number")
Tocopypast = Tocopypast & iProperties.Value(oRefDoc.DisplayName, "Project", "Part Number") & " OR "
Clipboard.SetText(Tocopypast)
IsRHS = False
Next
MessageBox.Show(wrongDisplayname, "Use RHS material")
End Sub
Public Sub debug(txt As String)
	Trace.WriteLine("NTI : " & txt)
End Sub
FINET_Laurent
Just looking through I don't see Length variable declared anywhere?
Maybe declaring it as double will help ?
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
it seems that it can´t convert an string with number and unit to an pure number
the string is somthing like "361 mm"   it say Can´t change stregen "361,0 mm" to duble
JhoelForshav
Hi @Darkforce_the_ilogic_guy
I wrote this function (GetDoubleVal) for you to convert the value to a double. See example below:
Sub Main
Dim oLength = "1234.56 mm"
Dim oLengthDouble = GetDoubleVal(oLength)
MsgBox(oLengthDouble)
End Sub
Function GetDoubleVal(oValue As Object) As Double
	Return CDblAny(System.Text.RegularExpressions.Regex.Replace(oValue.ToString, "[A-Za-z ]", ""))
End Function
I ende up using this code to remove the mm form text, and use the varible to convert it to an Double
Dim messing As Double = Split(iProperties.Value(oRefDoc.DisplayName, "Custom", "G_L")," mm")(0)
