Search all derived parts inside an assembly, open each of them and do something and close again
Charlies_3D_T
Message 1 of 31
Charlies_3D_T
I am not able to get a working rule for the following:
I want to scan an assembly and all it's sub assemblies to see how many derived parts there are. After that i want to open eacht of them get a message with info and close the open one and open the next.
Can someon of you guys give me a hint or a beginning for this? Because i keep struggling and don't get it working.
Thank you!
Accepted solutions (3)
Replies (30)
Message 2 of 31
bradeneuropeArthur
You mean?
If a part in an assembly contains a part that is deriving another part. You want to open it do something and close it?
Correct?
Do you need it recursive?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 31
Charlies_3D_T
Yes i have some parts that are derived parts. And i want to find all the parts that are derived parts and open these parts and run a rul inside them and then close them and open the next if there are multiple inside the assembly.
I don't understand what you mean with recursive?
Message 4 of 31
_dscholtes_
Well, here's a part of VBA code of mine travelling through all occurrences of an assembly and all derived parts in each occurrence. Note: Occurrences is passed as an argument to the sub this code is in and the check for solid bodies is just added as reference.
Dim oOcc As ComponentOccurrence
Dim oOccCompDef As PartComponentDefinition
Dim oDerivPart As DerivedPartComponent
'Iterate through all the occurences
For Each oOcc In Occurrences
  'Set reference to componentdefinition of current occurrence
  Set oOccCompDef = oOcc.Definition
    'Go through all derived parts
    For Each oDerivPart In oOccCompDef.ReferenceComponents.DerivedPartComponents
    'Check for solid bodies
    If oDerivPart.SolidBodies.Count > 0 Then
      <do something>
  Next oDerivPart
Next oOcc
And if you want to get info from derived assemblies, here's another piece of VBA code. Note: Occurrences is passed as an argument to the sub this code is in and the name retrieval is just added as reference.
'Declarations
Dim oDerivAss As DerivedAssemblyComponent
Dim oRefFeat As ReferenceFeature
Dim sRefFeatName As String
  'Go through all derived assemblies
  For Each oDerivAss In oOccCompDef.ReferenceComponents.DerivedAssemblyComponents
    'Go through all derived features
    For Each oRefFeat In oDerivAss.ReferenceFeatures
      'Check if there's a reference entity
      If Not oRefFeat.ReferencedEntity Is Nothing Then
        'Get the referenced entity name
        sRefFeatName = oRefFeat.ReferencedEntity.Name
        'Strip occurrence node index
        Dim t As Integer
        t = InStrRev(sRefFeatName, ":", , vbTextCompare)
        If t > 0 Then
          sRefFeatName = Left(sRefFeatName, t - 1)
    Next oRefFeat
  Next oDerivAss
Next oOcc
And if you need help travelling through an assembly by occurrences, here is a nice blogpost about it: https://modthemachine.typepad.com/my_weblog/2009/03/accessing-assembly-components.html
Message 5 of 31
Charlies_3D_T
I get an error when i try this:
Can you see what i do wrong?
Sub Main()
Dim oDoc As Document
oDoc = ThisDoc.Document
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oDoc.ComponentDefinition
'define the property set
Dim userParams As UserParameters = oDoc.ComponentDefinition.Parameters.UserParameters
Try
    BendRadius_Parm = oDoc.ComponentDefinition.Parameters("BendRadius_Ilogic")
Catch
    Dim newParam As UserParameter = userParams.AddByExpression("BendRadius_Ilogic", 1, "mm")
End Try
If oCompDef.HasFlatPattern = False Then
oCompDef.Unfold
Events
iProperties.Value("Custom","Length") = (Round(SheetMetal.FlatExtentsLength,0))
iProperties.Value("Custom","Width") = (Round(SheetMetal.FlatExtentsWidth,0))
iProperties.Value("Custom", "Thickness") = Parameter("Thickness")
iProperties.Value("Custom", "Profile") = "SM " & (Round(SheetMetal.FlatExtentsLength,0)) & "x" & (Round(SheetMetal.FlatExtentsWidth,0)) & "x" & Parameter("Thickness")
'SheetMetal_Hole
Else
'SheetMetal_Hole
      SheetMetal_Hole_Manueel
  Next oDerivPart
Next oOcc
End Sub
Message 6 of 31
bradeneuropeArthur
Public Sub main()
Dim oActDoc As Inventor.Document
Set oActDoc = ThisApplication.ActiveDocument
Call ReplaceFile(oActDoc)
End Sub
Public Sub ReplaceFile(oActDoc As Inventor.Document)
        Dim oFD As FileDescriptor
Dim oDoc As Inventor.PartDocument
        For Each oDoc In oActDoc.AllReferencedDocuments
        If oDoc.DocumentType = kPartDocumentObject Then
        On Error Resume Next
        MsgBox oDoc.ReferencedDocumentDescriptors.Item(1).ReferencedDocumentType = kPartDocumentObject
ElseIf oDoc.DocumentType = kAssemblyDocumentObject Then
Call ReplaceFile(oDoc)
        Next
    End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 31
Charlies_3D_T
I don't fully understand where i need to past the last part you shared with me.
Message 8 of 31
_dscholtes_
@Charlies_3D_T As I stated, the code is part of a function which uses arguments.
To get it working you need to change the following:
into
For Each oOcc In oCompDef.Occurrences
Message 9 of 31
J-Camper
@Charlies_3D_T,
You need to separate the assembly loop from your document processing rule.  It looks like you are doing stuff with Sheet metal parts too, so you need to verify SubType before you can set ComponentDefiniton.  Try this approach:
Sub Main
	'External rule lockout to avoid errors running code in wrong document type
	If ThisApplication.ActiveDocumentType <> kAssemblyDocumentObject Then MessageBox.Show("This rule is designed to only work in assembly documents.", "Wrong Document Type") : Exit Sub
	'Define Assembly
	Dim AsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
	'Search All referenced Documents
	For Each RefDoc As Document In AsmDoc.AllReferencedDocuments
		'Only look at part documents
		If RefDoc.DocumentType = kPartDocumentObject
			'Only look at referenced documents that exist as occurrences in the assembly
			If AsmDoc.ComponentDefinition.Occurrences.AllReferencedOccurrences(RefDoc).Count > 0
				'Anything in here is a Part Document that exists in the open assembly
				Dim PartDoc As PartDocument = RefDoc
				'make sure document has derived parts
				If PartDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Count > 0
					Logger.Debug("Derived Part Components in Part Document")
					'Process based on sub type if you have both sheet metal and normal parts
					If PartDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" 'Sheet metal sub type
						Call RunSMpart(PartDoc)
					Else 'Can be assumed to be normal part sub type
						Call RunNormalpart(PartDoc)
	Next
End Sub
Sub RunSMpart(SourceDoc As PartDocument)
	'Define Objects
	Dim pDoc As PartDocument = SourceDoc
	Dim pDef As SheetMetalComponentDefinition = pDoc.ComponentDefinition
	Logger.Debug("Defined Sheet Metal Part Document")
	MessageBox.Show("Do what you want for sheet metal parts", pDoc.DisplayName)
End Sub
Sub RunNormalpart(SourceDoc As PartDocument)
	'Define Objects
	Dim pDef As PartComponentDefinition = pDoc.ComponentDefinition
	Logger.Debug("Defined Normal Part Document")
	MessageBox.Show("Do what you want for normal parts", pDoc.DisplayName)
End Sub
You would need to fill in you other rule in the two sub routines.  Let me know if you have any questions, or if it is not working as intended.
Message 10 of 31
Charlies_3D_T
@J-Camper
I think my explination was not good.
I have the following situation:
1 have sm parts and i have sm parts that are derived parts from other sheet metal parts.
I have a rule inside these sm parts that search for threads and bends and that then fills in some custom properties.
If i have sheet metal parts that are derived these rules don't work because i can not see what is inside the master part. My solution was that when i have a derived part i ask the user to fill in the custom properties by hand.
But when i change an assembly where some sheet metals are inside and i save i get some errors. So i tried to call the part and open it but the rule is inside that part.
So it's not working like i was thinking. Is there an option to transfer the custom properties of some info from master part to the derived part? So that my normal sheet metal unfold rule and custom properties rule works also inside the derived sheet metal.
I hope the explaination is a bit better then my first question?
Message 11 of 31
J-Camper
So, would this rule live in your template file for all new sheet metal parts?  If so, I think this might give you what you need, or at least a starting point
This is written as a local rule that lives inside the Part Documents:
Sub Main
	'local sheet metal part rule.  No document typ checking
	Dim oDoc As Document = ThisDoc.Document
	Dim oCompDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition
	Try
	Catch
	End Try
	'New Code:
	'Set Object to collect values to names
	Dim PropList As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
	PropList.Add("Length", 20.5)
	PropList.Add("Width", 10.5)
	PropList.Add("Thickness", 1.5)
	PropList.Add("Profile", "Empty String")
	Logger.Debug("Setup NameValueMap")
	'Fill values based on whether or not there is a derived part
	If oCompDef.ReferenceComponents.DerivedPartComponents.Count > 0
		Logger.Debug("DerivedPartComponents Count > 0")
		Dim ParentDef As SheetMetalComponentDefinition = Nothing
		For Each RefDoc As Document In oDoc.ReferencedDocuments
			Logger.Debug("DerivedPartComponent Loop")
			If RefDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"
				Logger.Debug("Derived Comp Is SM")
				ParentDef = RefDoc.ComponentDefinition
				Exit For
		Next
		'I'm exiting here. if you have sheet metal parts with derived parts that are not Sheet Metal, this would be an issue
		If IsNothing(ParentDef) Then MessageBox.Show("No Derived Part was a Sheet Metal Part", "Termination") : Exit Sub
		'Otherwise it will be fine
		'Fill Values from Parent Document
		If ParentDef.HasFlatPattern = True
			Logger.Debug("Parent HasFlatPattern")
			PropList.Value("Length") = (Round(ParentDef.FlatPattern.Length,0))
			PropList.Value("Width") = (Round(ParentDef.FlatPattern.Width, 0))
			PropList.Value("Thickness") = ParentDef.Parameters("Thickness").Value
			PropList.Value("Profile") = "SM " & PropList.Value("Length") & "x" & PropList.Value("Width") & "x" & PropList.Value("Thickness")
		Else
			Logger.Debug("Parent Not HasFlatPattern")
			PropList.Value("Length") = FindMax(ParentDef.RangeBox, "L")
			PropList.Value("Width") = FindMax(ParentDef.RangeBox, "W")
	Else 'No Referenced Documents
		Logger.Debug("DerivedPartComponents Count <= 0")
		'Fill Values from open document
		If oCompDef.HasFlatPattern = True
			Logger.Debug("ThisDoc HasFlatPattern")
			PropList.Value("Length") = (Round(oCompDef.FlatPattern.Length,0))
			PropList.Value("Width") = (Round(oCompDef.FlatPattern.Width, 0))
			PropList.Value("Thickness") = oCompDef.Parameters("Thickness").Value
		Else
			Logger.Debug("ThisDoc Not HasFlatPattern")
			PropList.Value("Length") = FindMax(oCompDef.RangeBox, "L")
			PropList.Value("Width") = FindMax(oCompDef.RangeBox, "W")
	'Set iProperties
	Dim CustProps As PropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties")
	For i = 1 To PropList.Count
		Try
			CustProps.Item(PropList.Name(i)).Expression = PropList.Value(PropList.Name(i))
		Catch
			CustProps.Add(PropList.Value(PropList.Name(i)), PropList.Name(i))
		End Try
	Next
End Sub
Function FindMax(aBox As Box, Selection As String) As Double
	Dim Result As Double = 0
	Dim DeltaX As Double = Round((aBox.MaxPoint.X - aBox.MinPoint.X),0)
	Dim DeltaY As Double = Round((aBox.MaxPoint.Y - aBox.MinPoint.Y),0)
	Dim DeltaZ As Double = Round((aBox.MaxPoint.Z - aBox.MinPoint.Z),0)
	If Selection = "L" 'Length is longest
		If DeltaX > DeltaY And DeltaX > DeltaZ
			Result = DeltaX
		Else If DeltaY > DeltaX And DeltaY > DeltaZ
			Result = DeltaY
		Else If DeltaZ > DeltaX And DeltaZ > DeltaY
			Result = DeltaZ
	Else If Selection = "W" 'Width is middle value
		If DeltaX > DeltaY And DeltaX < DeltaZ
			Result = DeltaX
		Else If DeltaY > DeltaX And DeltaY < DeltaZ
			Result = DeltaY
		Else If DeltaZ > DeltaX And DeltaZ < DeltaY
			Result = DeltaZ
	Return Result
End Function
Let me know if you have any questions, or if this is not working as intended.
Message 12 of 31
Charlies_3D_T
@J-Camper
Something is not working. I get the dimension of 20 in my parameters in my derived part. So it does not add the correct parent values. THis is what i have:
Sub Main
	Try
	Catch
	End Try
	'New Code:
				Exit For
		Next
		Else
			SheetMetal_Hole
		Else
			oCompDef.Unfold
			Events
			SheetMetal_Hole
	'Set iProperties
		Try
		Catch
		End Try
	Next
End Sub
			Result = DeltaX
			Result = DeltaY
			Result = DeltaZ
			Result = DeltaX
			Result = DeltaY
			Result = DeltaZ
	Return Result
End Function
Sub Events
	Dim EventPropSet As Inventor.PropertySet
	EventPropSet = GetiLogicEventPropSet(ThisApplication.ActiveDocument)
	' To make sure that the document has an iLogic DocumentInterest, add a temporary rule
	Dim tempRule = iLogicVb.Automation.AddRule(ThisDoc.Document, "TemporaryRule_392856A2", "")
	EventPropSet.Add("file://COS_FlatPattern", "PartBodyChanged", 1250)
	EventPropSet.Add("file://BendRadius", "BeforeDocSave1", 701)
	EventPropSet.Add("file://COS_Sheet_Metal_Unfol_Rule_Trumpf", "BeforeDocSave2", 702)
	iLogicVb.Automation.DeleteRule(ThisDoc.Document, tempRule.Name)
'After Open Document					: AfterDocOpen                 		: 400
'Close(Document)						: DocClose                     		: 500
'Before Save Document                   : BeforeDocSave           			: 700
'After Save Document               		: AfterDocSave               		: 800
'Any Model Parameter Change        		: AfterAnyParamChange   			: 1000
'Part Geometry Change**            		: PartBodyChanged         			: 1200
'Material Change**                  	: AfterMaterialChange     			: 1400
'Drawing View Change***               	: AfterDrawingViewsUpdate  			: 1500
'iProperty(Change)                  	: AfterAnyiPropertyChange           : 1600
'Feature Suppression Change**          	: AfterFeatureSuppressionChange   	: 2000
'Component Suppression Change*   		: AfterComponentSuppressionChange 	: 2200
'iPart / iAssembly Change Component* 	: AfterComponentReplace   			: 2400
'New Document                         	: AfterDocNew                  		: 2600
InventorVb.DocumentUpdate()
End Sub
Function GetiLogicEventPropSet(cDocument As Document) As Inventor.PropertySet
		iLogicEventPropSet = cDocument.PropertySets.Item("iLogicEventsRules")
		If iLogicEventPropSet Is Nothing Then
			iLogicEventPropSet = cDocument.PropertySets.Item("_iLogicEventsRules")
		If iLogicEventPropSet.InternalName <> "{2C540830-0723-455E-A8E2-891722EB4C3E}" Then
			Call iLogicEventPropSet.Delete
			iLogicEventPropSet = cDocument.PropertySets.Add("iLogicEventsRules", "{2C540830-0723-455E-A8E2-891722EB4C3E}")
			MsgBox ("Unable to create the Event Triggers property for this file!", , "Event Triggers Not Set")
			Err.Raise(1)
			Exit Function
	On Error GoTo 0
	Return iLogicEventPropSet
End Function
Sub SheetMetal_Hole
Dim Feature As PartFeature
Dim Features As PartFeatures
Features = ThisDoc.Document.ComponentDefinition.Features
i = 0
j = 0
k = 0
l = 0
For Each Feature In Features
	'check if its a hole
	If TypeOf Feature Is ExtrudeFeature And Feature.Suppressed = False And Feature.Name.Contains("Chamfer") Then
		'increment one
		i = i + 1
Next
For Each hole_cb As HoleFeature In Features.HoleFeatures
	If hole_cb.HoleType = HoleTypeEnum.kCounterSinkHole
'    Dim info_cb As HoleInfo = hole_cb.Info
 '   If (info_cb IsNot Nothing) Then
       j = j + 1
 '       ' Your hole changing code go's here
Next
For Each hole_tap As HoleFeature In Features.HoleFeatures
 '   Dim info_tap As HoleTapInfo = hole_tap.TapInfo
If hole_tap.Tapped = True Then
        k = k + 1
Next
	'TypeOf Feature Is ExtrudeFeature
	If Feature.Suppressed = False And Feature.Name.Contains("Flange") Then
		'increment one
		l = l + 1
	If Feature.Suppressed = False And Feature.Name.Contains("Contour Flange") Then
		'increment one
		l = l + 1
Next
' Get the active part document.
Dim invPartDoc As PartDocument = ThisDoc.Document
        'Get the custom property set.
Dim invCustomPropertySet As PropertySet = invPartDoc.PropertySets.Item("Inventor User Defined Properties")
'MessageBox.Show(i, "i")
'MessageBox.Show(j, "j")
'MessageBox.Show(k, "k")
'MessageBox.Show(l, "l")
If i = 0 And j = 0 And k = 0 And l = 0 Then
	iProperties.Value("Custom", "Operation_1") = "Laser cutting"
	iProperties.Value("Custom", "Operation_2") = ""
	iProperties.Value("Custom", "Operation_3") = ""
	iProperties.Value("Custom", "Operation_4") = ""
If i = 0 And j = 0 And k = 0 And l > 0 Then
	iProperties.Value("Custom", "Operation_2") = "Bending"
If i > 0 And j > 0 And k = 0 And l = 0 Then
	iProperties.Value("Custom", "Operation_2") = "Countersink"
	iProperties.Value("Custom", "Operation_3") = "Chamfer"
If i > 0 And j > 0 And k = 0 And l >  0 Then
	iProperties.Value("Custom", "Operation_3") = "Countersink"
	iProperties.Value("Custom", "Operation_4") = "Chamfer"
If i = 0 And j > 0 And k = 0 And l = 0 Then
If i = 0 And j > 0 And k = 0 And l >  0 Then
If i > 0 And j = 0 And k = 0 And l = 0 Then
	iProperties.Value("Custom", "Operation_2") = "Chamfer"
If i > 0 And j = 0 And k = 0 And l > 0 Then
If i > 0 And j = 0 And k > 0 And l = 0 Then
	iProperties.Value("Custom", "Operation_2") = "Tapping"
If i > 0 And j = 0 And k > 0 And l > 0 Then
	iProperties.Value("Custom", "Operation_3") = "Tapping"
If i = 0 And j = 0 And k > 0 And l = 0 Then
If i = 0 And j = 0 And k > 0 And l > 0 Then
If i = 0 And j > 0 And k > 0 And l = 0 Then
If i = 0 And j > 0 And k > 0 And l > 0 Then
	iProperties.Value("Custom", "Operation_4") = "Tapping"
End Sub
Message 13 of 31
Charlies_3D_T
@JCamper
I also added the unfold part with the derived part but it does not unfold my part. Thank you for the help with this one!
Sub Main
	Try
	Catch
	End Try
	'New Code:
				Exit For
		Next
		Else
			oCompDef.Unfold
			Events
			SheetMetal_Hole
			SheetMetal_Hole
		Else
			oCompDef.Unfold
			Events
			SheetMetal_Hole
	'Set iProperties
		Try
		Catch
		End Try
	Next
End Sub
			Result = DeltaX
			Result = DeltaY
			Result = DeltaZ
			Result = DeltaX
			Result = DeltaY
			Result = DeltaZ
	Return Result
End Function
Sub Events
End Sub
			Err.Raise(1)
			Exit Function
	On Error GoTo 0
End Function
Sub SheetMetal_Hole
i = 0
j = 0
k = 0
l = 0
		'increment one
		i = i + 1
Next
       j = j + 1
Next
        k = k + 1
Next
		'increment one
		l = l + 1
		'increment one
		l = l + 1
Next
End Sub
Sub SheetMetal_Hole_Manueel
'Features = Doc.Document.ComponentDefinition.Features
i = False
j = False
k = False
l = False
'Dim oDoc As Document
'oDoc = ThisDoc.Document
'docName0 = oDoc.FullFileName
'ThisApplication.CommandManager.ControlDefinitions.Item("AppZoomallCmd").Execut
'MessageBox.Show(docName0, "We will change the following part:")
i = InputRadioBox("Does the part has chamfered edges?", "Yes", "No", booleanParam, Title := "Chamfer")
j = InputRadioBox("Does the part has countersink holes?", "Yes", "No", booleanParam, Title := "Countersink")
k = InputRadioBox("Does the part has threaded holes?", "Yes", "No", booleanParam, Title := "Thread")
l = InputRadioBox("Does the part has bends?", "Yes", "No", booleanParam, Title := "Bends")
If i = False And j = False And k = False And l = False Then
If i = False And j = False And k = False And l = True Then
If i > 0 And j = True And k = False And l = False Then
If i = True And j = True And k = False And l = True Then
If i = False And j = True And k = False And l = False Then
If i = False And j = True And k = False And l = True Then
If i = True And j = False And k = False And l = False Then
If i = True And j = False And k = False And l = True Then
If i = True And j = False And k = True And l = False Then
If i = True And j = False And k = True And l = True Then
If i = False And j = False And k = True And l = False Then
If i = False And j = False And k = True And l = True Then
If i = False And j = True And k = True And l = False Then
If i = False And j = True And k = True And l = True Then
End Sub
Message 14 of 31
J-Camper
@Charlies_3D_T,
I didn't realize at first that you wanted to create the flat pattern if none existed.  That's why I added the range box Function.  I believe I have the Unfold integrated into the derived part portion.  Unfortunately the Parent document must be opened visibly in order to Unfold, but it appears to be working now, in my small sample parts.  I had to re-work the SheetMetal_Holes Sub in order to work with both Open document and Parent document when needed.
One thing I can't check are the 3 external rules you are creating Event Triggers for.  I can't verify they will work with both original and derived SheetMetal Parts.  If those are causing issues with derived parts too, I'll be happy to take a look at them.
New Code: [I'm not using the FindMax Function anymore, but I have left it in at the bottom]
Sub Main
	Try
	Catch
	End Try
	'New Code
	Logger.Debug("Setup NameValueMap 1")
				Exit For
		Next
			Logger.Debug("HasFlatPattern")
			Logger.Debug("Parent-existing FlatPattern Values: " & PropList.Value("Profile"))
			Call SheetMetal_Hole(ParentDef.Document, oDoc)
			Logger.Debug("Completed SheetMetal_Hole")
		Else
			Logger.Debug("Not HasFlatPattern")
			'Open parent document to create flat pattern.  It seems it must be open Visilby inorder to successfully unfold
			Dim ParentDoc As PartDocument = ThisApplication.Documents.Open(ParentDef.Document.FullDocumentName, True)
			Logger.Debug("Parent is visibly open")
			ParentDoc.ComponentDefinition.Unfold
			Logger.Debug("Parent is Unfolded")
			ParentDoc.Update
			Logger.Debug("Parent is Updated")
			ParentDoc.Save
			Logger.Debug("Parent is Saved")
			ParentDoc.Close
			Logger.Debug("Created Flat Pattern in Parent")
			PropList.Value("Length") = (Round(ParentDef.FlatPattern.Length,0))'FindMax(ParentDef.RangeBox, "L")
			PropList.Value("Width") = (Round(ParentDef.FlatPattern.Width, 0))'FindMax(ParentDef.RangeBox, "W")
			Logger.Debug("Parent-New FlatPattern Values: " & PropList.Value("Profile"))
	Else
			Logger.Debug("local-existing FlatPattern Values: " & PropList.Value("Profile"))
			Call SheetMetal_Hole(oDoc, oDoc)
		Else
			oCompDef.Unfold
			Logger.Debug("Open Part is Unfolded")
			oDoc.Update
			Logger.Debug("Open Part is Updated")
			oDoc.Save
			Logger.Debug("Open Part is Saved")
			PropList.Value("Length") = (Round(oCompDef.FlatPattern.Length,0))'FindMax(oCompDef.RangeBox, "L")
			PropList.Value("Width") = (Round(oCompDef.FlatPattern.Width, 0))'FindMax(oCompDef.RangeBox, "W")
			Logger.Debug("local-new FlatPattern Values: " & PropList.Value("Profile"))
	'Set iProperties
		Try
		Catch
		End Try
	Next
	Call Events
End Sub
Sub Events
End Sub
			Err.Raise(1)
			Exit Function
	On Error GoTo 0
End Function
Sub SheetMetal_Hole(ValuesDoc As PartDocument, OpenDoc As PartDocument)
	Features = ValuesDoc.ComponentDefinition.Features
	i = 0
	j = 0
	k = 0
	l = 0
			'increment one
			i = i + 1
	Next
	       j = j + 1
	Next
	        k = k + 1
	Next
			'increment one
			l = l + 1
			'increment one
			l = l + 1
	Next
	Logger.Debug("i="& i &"  j=" & j & "  k=" & k & "  l=" & l)
	PropList.Add("Operation_1", "")
	PropList.Add("Operation_2", "")
	PropList.Add("Operation_3", "")
	PropList.Add("Operation_4", "")
	Logger.Debug("Setup NameValueMap 2")
		PropList.Value(PropList.Name(1)) = "Laser cutting"
		PropList.Value(PropList.Name(2)) = ""
		PropList.Value(PropList.Name(3)) = ""
		PropList.Value(PropList.Name(4)) = ""
	Else If i = 0 And j = 0 And k = 0 And l > 0 Then
		PropList.Value(PropList.Name(2)) = "Bending"
	Else If i > 0 And j > 0 And k = 0 And l = 0 Then
		PropList.Value(PropList.Name(2)) = "Countersink"
		PropList.Value(PropList.Name(3)) = "Chamfer"
	Else If i > 0 And j > 0 And k = 0 And l >  0 Then
		PropList.Value(PropList.Name(3)) = "Countersink"
		PropList.Value(PropList.Name(4)) = "Chamfer"
	Else If i = 0 And j > 0 And k = 0 And l = 0 Then
	Else If i = 0 And j > 0 And k = 0 And l >  0 Then
	Else If i > 0 And j = 0 And k = 0 And l = 0 Then
		PropList.Value(PropList.Name(2)) = "Chamfer"
	Else If i > 0 And j = 0 And k = 0 And l > 0 Then
	Else If i > 0 And j = 0 And k > 0 And l = 0 Then
		PropList.Value(PropList.Name(2)) = "Tapping"
	Else If i > 0 And j = 0 And k > 0 And l > 0 Then
		PropList.Value(PropList.Name(3)) = "Tapping"
	Else If i = 0 And j = 0 And k > 0 And l = 0 Then
	Else If i = 0 And j = 0 And k > 0 And l > 0 Then
	Else If i = 0 And j > 0 And k > 0 And l = 0 Then
	Else If i = 0 And j > 0 And k > 0 And l > 0 Then
		PropList.Value(PropList.Name(4)) = "Tapping"
	Logger.Debug("PropsList in SheetMetal_Hole is set")
	'Set iProperties
	Dim CustProps As PropertySet = OpenDoc.PropertySets.Item("Inventor User Defined Properties")
		Try
		Catch
		End Try
	Next
End Sub
			Result = DeltaX
			Result = DeltaY
			Result = DeltaZ
			Result = DeltaX
			Result = DeltaY
			Result = DeltaZ
	Return Result
End Function
Let me know if you are still having issues.  If it is still not working properly, it would help to have a copy of the files which are causing errors, so I can address them first hand.  Also running the rule in Log Level: Debug will print all the debug lines to the iLogic Log which would help determine where you might be getting errors.
DO NOT POST CONFIDENTIAL DOCUMENTS
Message 15 of 31
Charlies_3D_T
No i still don't get an unfold on my derived part...
The flat pattern rule is the one you adjusted. I want it to be past in the partbodychange for when i change something the parameters are updated.
The rest works. So i hope you can see whats wrong with the rule with the 2 files in attachment.
Message 16 of 31
J-Camper
@Charlies_3D_T,
Oh, my misunderstanding again.  I was checking the derived part parent document for flat pattern and creating it in the parent if it didn't exist.  You just need the Derived part parent for the "SheetMetal_Hole" sub routine, to check features.  You still want to use the Derived part to get the flat pattern extents from, correct?
Let me see what i need to change.
Message 17 of 31
J-Camper
@Charlies_3D_T,
I think this is it, it is now creating the flat pattern in the open document regardless of if it was derived or not:
Sub Main
	'local sheet metal part rule.  No document type or subtype checking checking
	Try
	Catch
	End Try
		Logger.Debug("existing FlatPattern Values: " & PropList.Value("Profile"))
	Else
		oCompDef.Unfold
		oDoc.Update
		oDoc.Save
		PropList.Value("Length") = (Round(oCompDef.FlatPattern.Length, 0))'FindMax(oCompDef.RangeBox, "L")
	'Set iProperties
		Try
		Catch
		End Try
	Next
	'Check for derived part parent to get features
				Exit For
		Next
		If IsNothing(ParentDef) Then Logger.Debug("No Derived Part was a Sheet Metal Part") : Exit Sub
		Logger.Debug("Completed SheetMetal_Hole on parent document")
Else
		Logger.Debug("Completed SheetMetal_Hole on open document")
	Call Events
End Sub
Sub Events
End Sub
			Err.Raise(1)
			Exit Function
	On Error GoTo 0
End Function
	i = 0
	j = 0
	k = 0
	l = 0
			'increment one
			i = i + 1
	Next
	       j = j + 1
	Next
	        k = k + 1
	Next
			'increment one
			l = l + 1
			'increment one
			l = l + 1
	Next
	'Set iProperties
		Try
		Catch
		End Try
	Next
End Sub
Let me know, if it is still not working as expected
Message 18 of 31
Charlies_3D_T
In the open document? If i press save in an assembly when the parts are
updated then the rule also will run?
Message 19 of 31
J-Camper
@Charlies_3D_T,
I'm not sure you want to set this rule to an event trigger for "BeforeSave" because we have to save the document after creating the flat pattern and making iProperty changes. I tried this and got save errors because the documents were activating the rule mid rule when saving the new flat patterns
What you can do with the modified code attached to this post, is call the rule to run from your assembly when ever you want them to update [This rule can be saved as an external rule or locally in your assembly level]:
Sub Main
	If ThisApplication.ActiveDocumentType <> kAssemblyDocumentObject Then Logger.Debug("Wrong Document Type: This rule is designed to only work in assembly documents.") : Exit Sub
	For Each co As ComponentOccurrence In ThisApplication.ActiveDocument.ComponentDefinition.Occurrences.AllLeafOccurrences
		Try
			iLogicVb.RunRule(co.Name, "Your SheetMetal iLogic Rule Name")
		Catch
		End Try
	Next
End Sub
The main change in the new modified code is this extra level of "Main Sub":
Sub Main
	'Check Active Document to Add return if running in assembly
	Dim ActiveDoc As Document = ThisApplication.ActiveDocument
	If ActiveDoc.DocumentType = kAssemblyDocumentObject
		Dim pDoc As PartDocument = ThisDoc.Document
		Logger.Debug("Running " & pDoc.DisplayName & "  From Assembly")
		ThisApplication.Documents.Open(pDoc.FullDocumentName)
		pDoc.Activate
		Call SM_Bundle(pDoc)
		Logger.Debug("From Assembly: " & pDoc.DisplayName & "  Complete")
		pDoc.Save
		pDoc.Close(False)
		ActiveDoc.Activate
		Logger.Debug("From Assembly: " & pDoc.DisplayName & "  Total Complete")
	Else If ActiveDoc.DocumentType = kPartDocumentObject And ActiveDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" 'Sheet metal sub type
		Logger.Debug("Running " & ActiveDoc.DisplayName & "  From It Self")
		Call SM_Bundle(ActiveDoc)
End Sub
Sub SM_Bundle(PassDoc As PartDocument)
       'Mostly the same as before but definitely copy from the attached text file
End Sub
Let me know if you are still having issues, if this is an acceptable update method, or if you have any questions.
Message 20 of 31
Charlies_3D_T
One thing i dont understand. The flat pattern rule i run normaly just
before i save then i get everything stored in the part.
This worked find but when i tried to get the parameter inside a derived
part this did not work anymore when i pressed save inside an assembly.
But the flat pattern rule needs to work when i save a part only or save all
parts inside an assembly. I will try your rule later today because i dont
fully understand why before save is not a good place to put this rule. You
would put it after save? Are the parameters then also stored inside the
part?
