script need for automatic name field in iprop
sebastien.forman
sebastien.forman
Hi all,
I would like to make an little automation script but i don' t know how i can do that.
I do the same movement many time by day.
When i have make a drawing, saving it with a correct name. (ex: 103-NiMo-10200-001 (Collection tank).idw)
I need to
-open 3d
-edit iprop
-put "103-NiMo-10200-001" (the first part of the file name) in field "Number part"
-put "Collection tank" (the second part of the file name) in field "Description"
-Save it
-Close it.
It would be really simpatic if someone could help me do this.
Thank
Sébastien
bradeneuropeArthur
The following:
Dim a As Application
Set a = ThisApplication
Dim b As DrawingDocument
Set b = a.ActiveDocument
Dim Partnr As Property
Dim Desc As Property
Dim propset As PropertySet
Set propset = b.PropertySets.Item("Design Tracking Properties")
Set Partnr = propset.Item("Part Number")
Set Desc = propset.Item("Description")
Dim Filen As String
Filen = b.DisplayName '"103-NiMo-10200-001 (Collection tank)" '
Dim strSp() As String
strSp = Split(Filen, " (")
MsgBox strSp(0)
MsgBox strSp(1)
Partnr.Value = strSp(0)
Desc.Value = Replace(strSp(1), ").idw", "")
End Sub
EDITTED>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
sebastien.forman
Hi bradeneurope
Thank you very much for this code.
Just the iprop you editing is of the idw file, but me, i want to edit iprop of the ipt or iam file show in this idw file.
Like show in screencasts.
Thank you again
Sébastien
bradeneuropeArthur
Keep reading than....
Public Sub main()
Dim bx As Document
Set bx = b.ReferencedDocuments.Item(1)
MsgBox bx.FullDocumentName
Set propset = bx.PropertySets.Item("Design Tracking Properties")
Dim Filen As String
MsgBox strSp(0)
MsgBox strSp(1)
End Sub
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
sebastien.forman
Yes,
Really nice,
just i need to refresh view after that because changet is not show.
It 's need to clic on model view list "assembly.iam" and after clic on buton  "mettre a jour".
I have tried to put bx.update or bx.rebuild, but doesn't work.
Have you an idea?
Sebastien
bradeneuropeArthur
bx.update2
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
sebastien.forman
No, bx.Update2 doesn't work too.
But b.Save work, juste need to save it a this time.
Thank you for your help.
Precious time will be saved in the future thanks to you.
