Save PDF
Save PDF
johan.degreef
Advisor Advisor
Save PDF
johan.degreef
For a long time this ilogic has worked without errors (maybe since 2025 was installed?)
Anyone have an idea? Many Thanks
Now I get this error:
Error on line 37 in rule: PDF_SAVE, in document: 23168_2001_9106.dwg
Unspecified error (0x80004005 (E_FAIL))
More info:
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (0x80004005 (E_FAIL))
at Microsoft.VisualBasic.CompilerServices.LateBinding.InternalLateCall(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack, Boolean IgnoreReturn)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateCall(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack, Boolean IgnoreReturn)
at ThisRule.Main() in external rule: PDF_SAVE:line 37
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at Autodesk.iLogic.Exec.AppDomExec.ExecCodeHere()
at Autodesk.iLogic.Exec.AppDomExec.ExecCodeInOtherDomain(AppDomain otherDomain, String assemName)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
oRevNum = iProperties.Value("project", "revision number")
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If oPDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 0
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2'oOptions.Value("Custom_End_Sheet") = 4
'get PDF target folder path
oFolder = "\\192.168.3.17\PDF_INVENTOR\"
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
 'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & oFileName & ".pdf"
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
'------end of iLogic-------
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
WCrihfield
Hi @johan.degreef.  I only quickly glanced over your code, but I think I see something that should be pretty easy to fix.  It looks like you have one to many directory separator characters ("\") between your 'Folder' and your 'FileName' parts.  Often the final "\" character is not included in 'paths', so we instinctively add one in there when concatenating path, name, and extension.  But in your case, since your 'path' is hardcoded text, and it includes that final "\", you just need to eliminate that, one place or the other.  Some folks have also used the System.IO.Path.Combine() method to combine 'path' and 'file name' portions together, because it seems to do a good job of inserting the correct directory separator character in there for us automatically, but that does take more code, and more processing, so maybe not the most efficient.
Wesley Crihfield
(Not an Autodesk Employee)
johan.degreef
No, eliminating that last "\" does not solve it....
bradeneuropeArthur
Hey Johan,
Inventor 2025 need to be .net8. You can find this in the help files.
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=GUID-522FF5BC-7CC5-43D5-99B1-14840CF54A82
If you need quick help please send me an email with the vb.net project
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
WCrihfield
Good catch Arthur.  I completely ignored the 2025 spec.  I know the newer system is more strict, so one other tip would be to 'Declare' (using Dim keyword) every variable, specifying its Type in the process.  Just doing that one extra step often eliminates errors.  Another tip would be to either stick with the 'ThisDoc' reference, and use 'ThisDoc.Document' for setting the value of your oDocument variable, instead of ThisApplication.ActiveDocument.  Or eliminate using the 'ThisDoc' term altogether, because it can be pointing to a different document than ThisApplication.ActiveDocument in some situations.  Mixing the two terms in one rule is usually not a good idea.  The line of code getting the revision number is not specifying which document to retrieve that information from either, so it is likely going to be focused on the same document as the 'ThisDoc' term, if there are two different documents involved.
Wesley Crihfield
Michael.Navara
Also you can try to publish PDF file to local TEMP folder and then copy the result to the network location
Dim oPath As String = ThisDoc.Path
Dim oFileName As String = ThisDoc.FileName(False) 'without extension
Dim oRevNum As String = iProperties.Value("project", "revision number").ToString()
Dim oPDFAddIn As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
Dim oDocument As Document = ThisApplication.ActiveDocument
Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
Dim oTempFolder As String = System.IO.Path.Combine(
    System.IO.Path.GetTempPath(),
    "PDF_INVENTOR")
'Check for the PDF TEMP folder and create it if it does not exist
If Not System.IO.Directory.Exists(oTempFolder) Then
    System.IO.Directory.CreateDirectory(oTempFolder)
'Set the PDF TEMP target file name
Dim tempPdfFileName As String = System.IO.Path.Combine(oTempFolder, oFileName & ".pdf")
oDataMedium.FileName = tempPdfFileName
'Publish document
'Check for the PDF FINAL folder and create it if it does not exist
Dim oFolder As String = "\\192.168.3.17\PDF_INVENTOR\"
Dim finalPdfFileName As String = System.IO.Path.Combine(oFolder, oFileName & ".pdf")
'Copy PDF from TEMP to FINAL folder
System.IO.File.Copy(tempPdfFileName, finalPdfFileName)
'Delete TEMP PDF file
System.IO.File.Delete(tempPdfFileName)
