- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
This is the code I've been using (borrowing):
SyntaxEditor Code Snippet
'------start of iLogic-------'oPath = ThisDoc.Path C:\Dwf oPath = "C:\Dwf" oFileName = ThisDoc.FileName(False) 'without extension'oRevNum = iProperties.Value("Project", "Revision Number") oPartNum = iProperties.Value("Project", "Part Number") oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _ ("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oDocument = ThisApplication.ActiveDocument oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium 'get PDF target folder path oFolder = Left(oPath, InStrRev(oPath, "\")) & "Dwf" 'Check for the PDF folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If iName = iProperties.Value("Project", "Part Number") MessageBox.Show( oPath, iName) 'Set the dwf target file name oDataMedium.FileName = oFolder & "\" & iName & ".dwf" 'Publish document oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) '------end of iLogic-------
It works - it was for pdf but changing the extension to .dwf works too.
Changing the top line from:
oPath = "C:\Dwf"
to:
oPath = "%userprofile%\documents\Dwf"
doesn't work.
I'd like the save destination to be here:
The user's can't save to the C\: drive just to their profile.
The plan is to run the code as an external rule across the network.
Multiple users being able to save as locally.
Andrew
