Adding suppressed parts to be included in rule
Message 1 of 1
I have the following code that works fine on all non-suppressed parts/sub assemblies...what code do I use to INCLUDE any suppressed parts/sub assemblies?
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 9812 StartFragment: 314 EndFragment: 9780 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
Sub Main()
    Dim oAsmDoc As AssemblyDocument = ThisDoc.Document
    ' Get the project number from user
    ProjectNo = Job_Number
    ' Change Project iProperty in Main Assemblhy
    iProperties.Value("Project", "Project") = ProjectNo
    ' Call recursion function
    Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1, ProjectNo)
    Call oAsmDoc.Update
End Sub
Private Sub TraverseAssembly(Occurrences As ComponentOccurrences, _
Level As Integer, ProjectNo As String)
Dim oOcc As ComponentOccurrence
    For Each oOcc In Occurrences
        'Change Project iProperty for all
        iProperties.Value(oOcc.Name, "Project", "Project") = ProjectNo
        ' Check to see if this occurrence represents a subassembly
        ' and recursively call this function to traverse through it.
        If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
            Call TraverseAssembly(oOcc.SubOccurrences, Level + 1, ProjectNo)
    Next
End Sub
Replies (0)
