Save flat pattern as dxf with bend line and layers
11:58 AM
- Mute
- Permalink
- Report
I Have a code to export all sheet metal flat pattern from an assembly that was working good till new need companie,
i need to be able to customize layers and export bed line and or etched line. it look like i'm near to make work, but i can not figure what i'm missing here. Need Help! Here's
Sub Main()
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
For Each oRefDoc In oRefDocs
SMPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) -4) & ".ipt"
Dim FNamePos As Long
FNamePos = InStrRev(oRefDoc.FullFileName, "\", -1)
Dim docFName As String
docFName = Right(oRefDoc.FullFileName, Len(oRefDoc.FullFileName) -FNamePos)
If oRefDoc.DocumentSubType.DocumentSubTypeID = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
oRefDoc = ThisApplication.Documents.Open(SMPathName, True)
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oRefDoc.ComponentDefinition
oCompDef.FlatPattern.Edit
If oCompDef.HasFlatPattern = False Then
oCompDef.Unfold()
Else
oCompDef.FlatPattern.Edit()
End If
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PR?OFILE"
oCompDef.DataIO.WriteDataToFile(sOut,docFName)
oCompDef.FlatPattern.ExitEdit()
oPath = ThisDoc.Path
Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
oMat = iProperties.Material(docFName)
oThickness = iProperties.Value(docFName, "Custom","G_T")
oDXFFolder = oPath & "\Plasma-DXF\" &"\" & oMat &"\"& oThickness &"\"
oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName) -4) & ".dxf"
oDXFName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) -4) & ".dxf"
oDXFFolder2 = oPath & "\Plasma-DXF\"
If Not System.IO.Directory.Exists(oDXFFolder) Then
System.IO.Directory.CreateDirectory(oDXFFolder)
End If
oDataMedium.FileName = oDXFFolder & oFileName
DefaultChoice = True
Dim Cm As CommandManager = ThisApplication.CommandManager
Cm.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent,oDataMedium.FileName)
Dim oCDef As ControlDefinition
'oCDef = Cm.ControlDefinitions.Item("GeomToDXFCommand")
oCDef.Execute()
oDef = ThisApplication.CommandManager.ControlDefinitions.Item("PartSwitchRepresentationCmd")
oDef.Execute
oRefDoc.Close
End If
Next
MessageBox.Show("New Files Created in: " & vbLf & oDXFFolder2, "iLogic")
Shell("explorer.exe " & oDXFFolder2,vbNormalFocus)
End Sub
de code
