iLogic add iproperties from Excel
jishee
Message 1 of 9
jishee
I have a rule that adds custom iProperties to parts in an assembly from an Excel file. The rule runs as expected the first time it is run, however if I make a change to the Excel file and run the rule again to update the iProperties, I get an error. The rule is below. I am not advanced enough yet (but learning lots) to determine why it runs the first time but not again after changes. Thank you for any help.
oDocFile = ThisDoc.Document
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oOcc As ComponentOccurrence
Dim oDocFileName As String
Dim oFileNamePos As Long
For Each oOcc In oAsmCompDef.Occurrences
If Not TypeOf oOcc.Definition Is VirtualComponentDefinition Then
	oDocFile = oOcc.Definition.Document
	'Find position in full filename path string where component filename begins
	oFileNamePos = InStrRev(oDocFile.FullFileName, "\", - 1)
	'Strip off filename path string and set oDocFileName to just the component's file name
	oDocFileName = Mid(oDocFile.FullFileName, oFileNamePos + 1, Len(oDocFile.FullFileName) - oFileNamePos)
			'Set your delimiter
			Delimiter = InStr(oDocFileName, "-")
			Description = Left(oDocFileName, Delimiter - 1)
			'Open the Excel file
			GoExcel.Open("C:\Users\jishee\Documents\Work\Inventor_modeling\iLogic\Unit_Drawing_Tests\Part_iProperties.xlsx", "Parts")
			'Look at the first 15 rows of the Excel file
			'Start at row 2, since row 1 contains headings
			For rowCheck = 2 To 15
				'Compare the part name to the value in column A
        		If GoExcel.CellValue("A" & rowCheck) = Description Then
           			iProperties.Value(oDocFileName, "Custom", "Extrusion") = GoExcel.CellValue("B" & rowCheck)
           			iProperties.Value(oDocFileName, "Custom", "Alloy-Temper") = GoExcel.CellValue("C" & rowCheck)
           			iProperties.Value(oDocFileName, "Custom", "Material") = GoExcel.CellValue("D" & rowCheck)
           			iProperties.Value(oDocFileName, "Custom", "Finish") = GoExcel.CellValue("E" & rowCheck)
           			iProperties.Value(oDocFileName, "Custom", "Color") = GoExcel.CellValue("F" & rowCheck)
           			iProperties.Value(oDocFileName, "Custom", "Hydro Code") = GoExcel.CellValue("G" & rowCheck)
           			iProperties.Value(oDocFileName, "Custom", "Routing") = GoExcel.CellValue("H" & rowCheck)
           			iProperties.Value(oDocFileName, "Project", "Description") = GoExcel.CellValue("I" & rowCheck)
			Next
			GoExcel.Open("C:\Users\jishee\Documents\Work\Inventor_modeling\iLogic\Unit_Drawing_Tests\Part_iProperties.xlsx", "Infills")
	       			iProperties.Value(oDocFileName, "Custom", "Routing") = GoExcel.CellValue("B" & rowCheck)
	       			iProperties.Value(oDocFileName, "Project", "Description") = GoExcel.CellValue("C" & rowCheck)
	       			iProperties.Value(oDocFileName, "Custom", "Make-up") = GoExcel.CellValue("D" & rowCheck)
			Next
Next oOcc
Replies (8)
Message 2 of 9
marcin_otręba
can you show what error you get?
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 3 of 9
jishee
It shows up on the "Description" line between the message boxes.
Message 4 of 9
marcin_otręba
maybe it does not find “-“ in docname? in first message show delimiter and see its value.
Message 5 of 9
jishee
It gives Delimiter = 0.
Message 6 of 9
marcin_otręba
i am not at computer right now but first line is confounding,please delete it. also instead of delimiter show docfile fullfilename, than you will know what happened.
Message 7 of 9
Sergio.D.Suárez
Hi, why don't you try to put the instruction on error resume next to see if it skips the error and continues with the execution.
I made some changes to your rule and remove what I thought was not necessary, try the code and see if it does what you need.
Dim AssyDoc As AssemblyDocument = ThisDoc.Document
Dim oAsmCompDef As AssemblyComponentDefinition = AssyDoc.ComponentDefinition
Dim oDocFile As Document, oDocFileName As String
For Each oOcc  As ComponentOccurrence In oAsmCompDef.Occurrences
		On Error Resume Next
		oDocFileName = oDocFile.displayname
		'Set your delimiter
		Next
		Next
Next oOcc
If you find an error you can alternately insert a message box inside your rule to search for the source of the error.
I hope some of this can be useful to you. Cheers
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 8 of 9
Darkforce_the_ilogic_guy
the reason that you can run it one time and not the second is that you forgot to close the excel file
need to  add
GoExcel.close
after you are done using it ..  go into joblist and find and force close all excel program and see it work again.
remember to add the GoExcel.Close code if you want to use it more then one time
Message 9 of 9
jishee
Thank you @Sergio.D.Suárez  and @Darkforce_the_ilogic_guy . It is working fine now.
